Question about Samsung Televison & Video
I have sp43t8hex/xec Samsung with convergence problem stk392-010 its ok,convergence corection is working from service menu but not corectly
Slinteriors
  • 8617 Answers
SOURCE: convergance
You most likely have some resistors that are needing to be replaced its not uncommon for Samsungs ICs to open a couple resistors when the ICs go out and installing new ICs with the old ones being open can cause more of the convergence resistors to burn. Post the model number of you set and I can let you know which resistors you likely need to replace.
Posted on Jun 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung STK392-010 ICs Convergence Issue.
Its a fairly straight forward repair. i would recomend getting your replacement Ics at the following link, as they provide free instaltion instructions with pictures, free shipping and free online instant messageing when you do the repair in case you need assistance. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 17, 2008
ladywinn
  • 5138 Answers
SOURCE: Hitachi 51gwx20b service code
There is not a Service code to Enter into convergence on this set , on convergence board there is a switch on the very front of board WITH set on press and hold 3secs you should see convergence Pattern Appear after you release button. From the Front of TV remove Bottom cover then you will be able to see whole chassis,and the Little Blue contact switch.on same board you replaced ICs.
Posted on Jan 10, 2009
  • 1779 Answers
SOURCE: STK392-010
The value you are looking for is 3.9 ohm. Just ohm them out and replace the ones that are not right on the money= very important for longevity. Don't forget to clean and apply new heat sink compound to the heat sinks.
Posted on Mar 28, 2009
Slinteriors
  • 8617 Answers
SOURCE: Convergence problem Samsung HC-P4752W
check the 3.9 ohm resistors as well as some of them may be open also
Posted on Mar 29, 2009
Where can I buy an automatic convergence control module for my Toshiba 51h3 rear projection TV
Hello
There is no detail about the convergence control module you specifies here. It will be best to contact the nearest Authorised Service center for Toshiba at your town about its details. They will have the original convergence board with them. There is no other source to get it. No data is available at NET too. OK.
Oct 26, 2011 | Televison & Video
I own a RCA d52w20 and the convergence is terribly bad. I set it up, used auto convergence and even went to the service menu for the 25 point setup. But my screen is still terribly bowed and i cannot find...
Try this with TV off Press and Hold CH- VOL- at same Time Hold untill TV comes on.
Then you should be in Factory setting menu, it will either corect the Problem its self or go straight to Service Menu for Techicians.
Feb 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
E000
if I remember corect E000 means that inadequate rise in temperature of the fixing unit at power-on
You must enter in service mode end acces the menu CLEAR and activate ALL.
You can enter in Service Mode like this:
press Service Key, press # key
press left arrow until CLEAR appears on display
press OK
press left arrow until ALL appears on display
press OK, the machine restarts and you should be able to use the machine.
Nov 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
When i try to charge my samsung icon phone it comes up with an exclamation what does that mean
I believe that means that the charger is not working corectly or it is not supported (If it is a generic charger the second is most likely).
If it is not supported: Then buy one that is form Samsung, not a generic.
If it is not working correctly: Try contacting their costumer service.
Apr 20, 2010 | Samsung Cell Phones
Blue out spec con not corect with convergnce
No thats a convergence Failure. Your model is in the PT53WX53 series. You can get the convergence repair kit at www.tvrepairworld.com for your model. The kit contains the new ICs the six resistors and the CD with repair instructions.
Nov 26, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Jan 10, 2009 | Hitachi 51GWX20B 51" Rear Projection...
Riso cr 1610
You will have to select corect machine model in service mode 200 , nomaly it is d but you will have to select between 1 and f to find the corect setting or just make sure that your cable is connected corectly
Nov 12, 2008 | Riso RZ220 Duplicator
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Open Questions:
Televison & Video Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
