Question about Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster
Instructions for Sandwich Toaster 9255 - Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster
How do I clean it after grilling
Gloria, All the links can show how to clean after grilling.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Wash Toasters and Sandwich makers
What the best way to clean panini press with non removable sides
How to Clean Sandwich Toaster Helpful Tips to Cleaning Your Kitchen...
Easy tips for cleaning an electric grill
Apr 19, 2016 | Kitchen Appliances - Others
Where can I get it repaired?
How to fix and open, Sandwich Maker Disassembly - YouTube
? 5:05
https://www.youtube.com/watch?v=HAsnk6qebDw
Apr 9, 2015 - Uploaded by Teo Zb?rcea
7:09. Chicken Recipes - How to Make Chicken Panini - Duration: 2:49. by Allrecipes 126,361 views. 2:49. Beginning TechsRepairing a Toaster ...
How to Repair a Toaster - How to Repair Small Appliances ...
Dec 25, 2015 | Kitchen Appliances - Others
1978 ge toaster
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
Nov 19, 2013 | Dualit Kitchen Appliances - Others
Need manual for VST004 Sanwich toaster
Hi there.
I have seen Breville Owner's Manual but only for BTS400 4-Slice Sandwich Maker.
If this is the one you are looking for, you can download it at http://www.breville.com.au
Regards.
Jul 16, 2011 | Breville VST004 Sandwich Maker
Instruction book for breville sandwich toaster SG18 required
Try this site. They have alot of small appliance manuals that you can download.
http://homeappliance.manualsonline.com/manuals/device
Jul 09, 2011 | Vacuums
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
Jun 14, 2011 | Microwave Ovens
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
I need instructions for Toaster VTT090
Below the only manuals for toasters available from breville.
Sandwich Toaster
Die Cast Model
Ikon model
Hope they can help
Mar 02, 2009 | Breville Kitchen Appliances - Others
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster Logo
61 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
