Question about Tilia Kitchen Appliances - Others
My FoodSaver will not stop vacuuming--it sucks the air out but the motor won't release unless I press Instant Seal. I opened the back, like some have suggested here, but I don't know what I'm looking for. There are two switches which click when I touch them. There doesn't seem to be a break in any wire. How can I tell about the circuit board?
I finally fixed my Foodsaver V2820. It was continually vacuuming and not switching from vacuum 1 to vacuum 2. I cleaned the foam vacuum channel gaskets and replaced them and it started working properly again. Try this before you take it apart and fiddle with the circuitry.
Posted on Nov 25, 2017
  • 11 Answers
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Posted on Jun 25, 2009
  • 2976 Answers
I had to take mine apart and clean the vacuum line out. It got tiny amounts of liquid in it over time and did the same thing. Before you take it apart, try setting the adjustment screw on the back. It's for altitude but, a slight turn could get you the results you need.
Posted on Feb 18, 2009
  • 2976 Answers
SOURCE: my foodsaver vac 550 vacuum works but it doesn't
Check the altitude adjustment. Also, check for food debris in the intake hole, tube or path. Check for debris on the rubber seal around the sealing strip.
Posted on Jul 21, 2009
  • 420 Answers
SOURCE: I have a foodsaver and it sucks the air out but
The bag is wrinkled or the gaskets are leaky, it has to pull down to a set vacuum in order to shut off and heat the strip to seal the bag. For the right now dilemma try pressing down on the lid while it's vacuuming and start looking for gaskets at foodsaver.com
Posted on Jun 18, 2010
  • 88 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
I have a foodsaver and it sucks the air out but won't seal. What do I do? We're trying to save some frozen fish and it just sucks and sucks but doesn't stop or seal. Any ideas?
May 29, 2010 | Tilia FoodSaver V2240
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Jan 08, 2010 | Tilia FoodSaver V2240
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
The Foodsaver V3460 will not open for cleaning. The left side appears to be releasing, but not the right. Your assitance is appreciated. Thanks, Steve
Just plug your unit back in and press the stop button, then it will release it automatically when you press the 2 green buttons, took a while for us to figure it out.
Oct 17, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Not sucking air out
Either the seal to the vacuum foot is not being made due to folds or improper placement, or more likely the filter for the vacuum has gotten plugged. Check out the path to the pump.
Sep 09, 2009 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
980 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
