Question about Refrigerators
Whirlpool refrigerator top freezer
Water from somewhere is getting into the cold cut bin and also laying on the bottom shelf (above the fruit and veggie bin) I cleaned and dried the bin yesterday and there is about 1/4 inch water in the bin again today. Is there anything I can check
  • Anonymous Mar 17, 2014
    Water in Fruit Bin
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Apr 08, 2008
SOURCE:
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
We have water laying on the bottom shelf every day
Under the evaporator coils is a drain. It catches the defrost water and directs it to a pan above the compressor where it evaporates. The drain clogs and water cascades down the back wall ending up under the crispers. Get a shop vac and open the drain.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 17, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Apr 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
