Question about Microsoft Xbox Console
Erroe message on screen "system error contact xbox support
When on on/off button is pressed it turns green as normal the the buttom right of the button turns red. Error message on the screen says:-" system error please contact xbox support.
  • Microsoft Master
  • 441 Answers
Is there an error code on the bottom of the screen?
E73?
E74?
E68?
E69?
Or another code?
Posted on May 28, 2010
Error 71 it keeps freezing
from : http://forums.xbox-scene.com/index.php?showtopic=484726
E71:
Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
Clear Any Failed system updates that cause the console to error.
  1. With the console off, press and hold the sync up button (the small white one)
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally
Jan 05, 2012 | Video Game Consoles & Games
My xbox keeps freezing when I play my games then sometimes I get an E 71 error??? what do i need to do?
E71: Dashboard Error - Error within Xam.xex
Try resetting the console - Clear All Installed Game Updates and Console Cache
  2. Select "memory"
  6. Select Yes
  4. During the boot process the console should clear any failed updates, allowing you to use it normally.
If that doesn't fix it, you'll need to set up a repair with MS.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Jun 27, 2011 | Video Game Consoles & Games
Xbox will not load up, has a red light glowing. screen displaying; contact xbox support Error E 79
Do a quick check to see if your Xbox will start up without the hard drive connected. If it does, you'll probably need to replace your hard drive. If you still get the error message, try the following: Clear Any Failed system updates that cause the console to error. 1. With the console off, press and hold the sync up button (the small white one) 2. While holding the sync button press the power button to turn on the console 3. Continue to hold the sync button until the Console has booted up completely. 4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Jun 11, 2011 | Video Game Consoles & Games
Microsoft Xbox 360 Wireless Controller When I
If the battery has run flat you may need to pair the controller to the Xbox, Switch on your Xbox and press the small button to the right of the memory card slots, the four green lights will start to flash. Now press the small button that is next to the socket on the front of the controller.
Dec 19, 2010 | Microsoft Xbox 360 Wireless Controller
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Our console goes to a black screan saying "system error. Contact customer support" in eleven different languages, and says E 7 1 at the bottom. Help?
  2. Select "memory"
  6. Select Yes
Sep 26, 2010 | Microsoft Xbox 360 Console
Xbox360 shown error E79
2. Select "memory"
6. Select Yes
Apr 04, 2010 | Microsoft Xbox Console
Error 71,what is that?when I load a game it loads,then screen goes black and says error 71
71 is usually cuased by a failed update that was installed or possibly a memory issue. Try these two soloutions and if they do not fix the issue, you have a hardware problem and you will need to send it in to Microsoft.
  2. Select "memory"
  6. Select Yes
Jan 23, 2010 | Microsoft Xbox 360 Console
E80 CODE WITH ONE RED LIGHT ON XBOX 360
Hardware failure
Make sure your A/V (or component) cables and power cable are connected properly. Take your hard drive off and turn the system on, then if it's fine turn it off, replace the HDD, and turn it on again.
if that dont work try this
--==Console Reset Codes==--
  2. Select "memory"
  6. Select Yes
Jan 17, 2009 | Microsoft Xbox 360 Console
Red light keeps flashing and it is showing an error screen that says E71
If the below doesn't work, you'l need to send it back to MSFT.
Clear All Installed Game Updates and Console CacheGo to the "system" blade
Select "memory"
Select Yes
Jun 17, 2008 | Video Game Consoles & Games
Microsoft Xbox Console Logo
124 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
