Question about Canon imageRUNNER 2200
Canon Imagerunner 220- Autofeeder not working
Canon Imagerunner 220- The automatic document feeder makes a sound as if its running- but the main wheel that seems to be the one that pulls the paper through doesn't look to be turning at all. The paper never moves and i am using the regular plate which is a pain when you have a large document to copy. any ideas?
  • 149 Answers
There is the possiblity that the document feed rollers and seperation pads are dirty and need cleaning and or replaced. and or the clutch that turns the rollers is slipping or burned out.
i would start with the rollers and pad they are least expensive and easiest to replace.
Posted on Jun 09, 2010
There is a black dotted line whenever I make copies on the cannon imagerunner 400s
It's either a speck on the scanner glass for the document feeder, or a smear of toner on one of the rollers. Check the skinny band of glass inside the document feeder for specks and clean it with a lint-free soft cloth and a little rubbing alcohol or a very little bit of water.
May 30, 2012 | Canon imageRUNNER 400S Copier
I have canon IR2010F copier with ADF and automatic feeder slips while taking the document in the feeder and makes tic tic tic tic noise while taking in the paper in the feeder, When we provide hand...
there are two locking handles for the adf on either side of the cover of adf i am sure one of them is broken or disfigured that why when u press it the adf works.i dont think this spare part is available u have to use ur own creative skills to make it through melting plastic to make a hook for that side
Jun 05, 2011 | Canon imageRUNNER 2010F Copier
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
I have a problem with the error e 051 some body help me
000 Fuser problem E010 Main motor, motor board, clock pulse E030 Counter E050 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E204 Document sensor, scan reverse sensor or scale E210 Lens problem E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
Jan 15, 2010 | Canon imageRUNNER 400S Copier
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
Document feeder for Canon Imagerunner 600
q le paso al de ustedes
para poder sugerirte
Feb 14, 2008 | Canon imageRUNNER 600 Printer
AutoFeeder Copy with Lines
TRY FOLLOWING THIS LINK http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=421991&dlc=en&lang=en
Oct 03, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Canon imageRUNNER 2200 Logo
75 people viewed this question
old marine
old marine
