Question about Whirlpool LSB6200KQ Top Load Washer
Machine only puts out water.wont spin.
No mater what i set it on,all i get is water.it wont spin.i put in a load and when it filled up,it stopped.
    Novelist:
  • 77 Answers
This is a typical problem. If the machine fills up and stops and makes absolutely no noise whatsoever, what you have here is a broken lid switch. The machine simply thinks the lid is open, and therefore does nothing. For your washer, you need a lid switch with a part number of 3949247. Naturally after cracking a machine open you may find uncommon things such as broken and/or burnt wires, but these are unpredictable and highly unlikely.
Posted on May 28, 2010
Lg top load washer keeps filling and has to be manually stopped but it will drain when put on the spin cycle.
HI,
From your description, it sounds like there may be a problem with the inlet water solenoid valve(s). They can stick after several years of use. The se valves are located in the machine, just inside where you connect the water hoses.
Jul 25, 2015 | LG Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Water wont stop filling.
I have similar problem. Looks like the 2nd possibility. but how to open the front panel to check the small pipe that goes to the water level switch, as I notice there is not water going up there.
Thanks.
Sep 20, 2009 | GE WWSE5200B Top Load Washer
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
My washer
It sounds like you have a faulty inlet valve or module. Hope this helps.
Oct 02, 2008 | Hotpoint Washing Machines
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
