Question about Toshiba Televison & Video
I have warped screen on my tv how can i fix it
  • 36 Answers
First of all, the darker the screen, the more it attracts sunlight and heat from the sun, so get the TV away from the window and out of the direct sunlight. Also keep the screen away from heat registers. This can also serve as a problem with dlp screens.
If you are savvy enough along with some common sense and ingenuity, you can straighten your screen in a couple manners.
First very carefully remove the screen and have a prepared flat and smooth surface layered with a perfectly 3 or 4 layer-folded sheet for it with absolutely no flaws on the surface that you will be laying it down on. You now have 2 options: 1. you can take it outside on that perfect sunny 85 degree day and let it sit just long enough to get nice and toasty warm, but not melty and lie another flawlessslly folded sheet with a perfectly smooth board over it to rest in the shade with weights on top of it to press it flat again, or: 2. you can iron it out in a meticulous manner with another layered sheet over it until it is flat again. Be careful with either method though. DON'T let any part of the panel get too hot or you could make it even worse. It will take your best attention to know how much heat is needed and when to stop applying the heat. And NEVER use a heat gun or blow dryer, because the panel is too big for hot air to work in a condensed area that guns and dryers offer. Those will only cause it to warp worse. Good luck
Posted on Jan 20, 2011
  • Jeramie
    Jeramie Jan 20, 2011
    this fix, of course, will only work if the actual screen itself is warped. If your picture is warped, then it's most likely a convergence problem and the heat trick will NOT work for convergence problems.
Screen is scrambled. Working fine until I unpluged the TV one day. Is it a fuse?
If it looks 3d or warped its a convergence problem
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself
Apr 22, 2011 | Hitachi 51F500 51" Rear Projection...
The picture can be seen, but it seems to have a rainbow aura and looks concaved...although the screen is not warped in any way...it was working perfectly last night...turned it on this morning, and we were...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2011 | Sony KP-65WS500 65" Rear Projection...
I have a Mitsubishi VS-60111 TV and the colors are messing up. When I go into the Convergence screen, the blue line is warped and will not let me move it back itno place. What do I need to do?
  • Screen looks 3D
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Jan 28, 2011 | Mitsubishi VS-60111 60" Rear Projection...
Warpped TV picture
There are two problems here but may be caused by one component
The flyback transformer or transistor equivalent is faulty The colors are warped convergence controls which may be due to a faulty sustain board or part of the first problem. DIY is not an option and repair estimate is about $3-400.00
Please rate my help++++Thanks for uyisng FIXYA
May 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
SNES games are warped on right side of TV screen
Well it might of been recked in a flood like my normal NES was and you can't fix it its not fixable. Sometimes the insurance company will take it away if that happens then.
Apr 23, 2010 | Nintendo Super NES Console
Screen looks warped
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 22, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Weird warped lines
Try the Magic Focus option on the menu.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Picture warped..Can't fix convergence because crosshairs are also warped!!
try these sites:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
different tv same problem, same solution
Dec 05, 2007 | Televison & Video
Mitsubishi diamond hd1080
It sounds like you will have to replace the convergence IC's in this TV set. Not a really hard repair to do but you will need to know how to solder and work on solid state printed circuit boards. Good Luck
Jun 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
