Question about Singer 5050 Mechanical Sewing Machine
Machine sewing backwards - Singer 5050 Mechanical Sewing Machine
The reverse lever may be stuck. this is usually located on the right hand side of the machine, and is a lever that you can push down. sometimes it's a switch.
Posted on Aug 11, 2010
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
6260 janome sewing machine will not pick up thread?
Needle damaged, in backwards, wrong needle, needle not fully up in the needle clamp; bobbin in backwards or wrong and/or machine out of time. User error is far more common than timing problems.
May 07, 2014 | Brother CS-8150 Computerized Sewing...
SINGER 132K6 sewing backwards only
Yes the wiring is backwards so the motor runs the opposite way.
May 18, 2013 | Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Backwards sewing machine
since the machine has been in storage for a few years, it probably needs to be serviced. oil & grease that are used in a sewing machine can become yecky & may be causing the machine to sew backwards or
the machine could have a loose or broken part. only a sewing machine shop can tell for sure.
Apr 16, 2012 | Janome Sewing Machines
Sewing machine sewing backwards??? help
reverse cam might be gunked up with old grease
Dec 10, 2009 | Singer Sewing Machines
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Only sews backwards
You probably have it in the buttonhole stitch.
Mar 23, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Singer 5050 Mechanical Sewing Machine Logo
156 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
