Question about iLO (2 GB) MP3 Player
Next Ok i got it to power up finnally, now it wont recognize a USB, and when u turn it on and then plug the USB into it, the player shuts down
  • 88 Answers
I think it is the Data Cable Complient please change it
Posted on Apr 17, 2008
SOURCE:
TRANSCEND MP330 ISSUE: i bought this player a year go and was working fine as mp3 and data storage, however i recently noticed my PC/Laptop has not detected the USB drive anymore but i can still listen to...
Do I understand correctly that your computer is still playing music that is only on your USB drive device but it does not recognize the device with a drive letter?
If you had to install a driver then uninstall it and try reinstalling it. If you did not have to install a driver or this doesn't help then shut the computer down. This means turn it off, no sleep, hibernate, or any other sort of shut down mode I mean really shut it off.
Unplug this device turn the computer back on and let it boot up completely.
Shut the computer down again, completely. Turn the computer back on and once it boots up completely try plugging your device back in and see if everything is now recognized. Does it beep when the device is plugged in the same way it did when you first plugged it in when you first got it?
If it still does not find your USB drive and it beeped differently then there's some problem with the computer seeing the device. My next attempt would be to check the USB wires to be sure they are still working, full continuity from one end to the other.
If all this is working then perhaps something may be wrong inside the device.
Nov 01, 2017 | Audio Players & Recorders
When I hook up my Sansa mp3 player to either delete or load music my computer says it doesn'r recognize the usb port
Hello
I am not saying that this is the correct solution, but is works for me each time. Just plug the mp3 player into one of the usb ports on at the back of your computer case.
One other thing you can try is:
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this can help you in fixing that pesky “USB device not recognized” Windows error!
Kind regards
Andrea
Nov 13, 2009 | SanDisk Sansa m250 MP3 Player
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Lexmark X3650 Printer
Boot error
Problem Solved: My MMP8567 screen read ''boot error shutting down''.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' 'Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver'' After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
May 06, 2009 | Memorex MMP8567 MP3 Player
My GoGear 8G wont come on
1. On you computer, ensure that Philips Device Manager is running.
2. Turn your mp3 player on (it should freeze at the Loading or GoGear Screen).
3. Plug in the mp3 player to your USB/Charger cable (ensure it is connected to the USB port on your computer), and then perform a soft reset (Power switch down and Volume up button simultaneously).
4. Let go of the other buttons as soon as the player resets. Hold the Volume down button until the player comes on. The player will be recognized by Philips Device Manager and will report a problem (and will allow you to repair it). Windows will also recognize it as a Mass Storage Device.
edit:
video: http://video.google.com/videoplay?do...56814975105076
Jan 15, 2009 | Philips GoGear SA5285/37 Digital Media...
Memorex mmp8567 boot error shutting down
Update the firmware. Download directly from Memorex site, Support section.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
Nov 30, 2008 | Memorex MMP8567 MP3 Player
Worked first then boot error now comp wont pick it up
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
Rca mp3 player h125
plug it into your computer and re-format it
Jan 24, 2008 | RCA Lyra RD2765 MP3 Player
Wont turn on
I had the same problem. Reset the device, by pushing the reset button down (a small hole next to the usb connector). Then hold down the play button for a few seconds. That should work. If that doesn't work, after reseting, hold down the play button and A-B Button for a few seconds.
Sep 28, 2007 | Samsung Yepp YP-T7JZ MP3 Player
iLO (2 GB) MP3 Player Logo
16 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
