Question about Wahl 8550
Forgot how to re-assemble wahl 8552
I have the 8552 model. My wife dis-assembled it to clean. She forgot how to re-assemble. Does any one have an exploded view of the trimmer so I can see how to re-assemble. Or written instructions would do fine. Your help would be greatly appreciated....................thanks.......Sam
4 Suggested Answers
SOURCE: re-assembling my Wahl Beard Trimmer Model # 9918C
Turn the trimmer off. Put your thumb under the teeth of the attachment. Push Up. The attachment should snap off. Replace the beard trimmer in the slot. Hope this helps.
Posted on Aug 26, 2009
rick_stokes_
  • 61 Answers
SOURCE: How to attach beard regulator on Wahl Groomsman
The attachment should hook over the teeth of the blades and then snap onto the back end.
Posted on Sep 27, 2009
SOURCE: I disassembled my Wahl 8552
How did you get it apart? I don't want to break the case and can't get it to release at the front of the unit.
Posted on Jan 17, 2011
Wahl 5598 blade assembly
Please contact Wahl by phone to purchase the needed item.
May 24, 2016 | Wahl Health & Beauty
My 8552 charger does not work. Where can I buy a new one
Mannys-sharpening.com is a Wahl Dealer they all parts for Wahl email them at ask@mannyssharpening.com
May 09, 2011 | Wahl 8550
I am needed to find a replacement charger for a wahl rechargeable clipper Model # 8552 It says that it need to be a PCC charger only. Need to know where and how much it would be.
i need a wahl replacement charger PCC as well!!! if anyone knows how to get on let me know because Wahl No Longer sells the clippers so they don't sell the charger now! that sucks wahl !! they should be able to sell you the charger when the charger goes bad like mine did ! it had a short in it and i accidently threw it away!!! now i don't know how to find a replacement charger?thanks
Jan 14, 2011 | Wahl Health & Beauty
I disassembled my Wahl 8552 Pro Series clippers do change the rechargeable batteries and now I can't figure out how to assemble it. I wind up with two extra screws.
Dec 15, 2010 | Wahl 8550
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
I have a Wahl clipper Pro Series Rechargeable model 9550 and can't figure out which charger goes to it. I have one labled for model 5550 only - is that it?
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
Mar 06, 2010 | Wahl 8550
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Wahl 8550 Logo
549 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
