Question about Stairmaster 4400CL Stepper
My Stair Climber 4400cl is making a clunking sound on both steps. After removing the covers I found the sound coming from the drive belt with teeth. Should I replace the gears as well as the belt?
  • alan_m_salga Jun 01, 2010
    thanks for the reply maxtreadmill. But my Stair Climber is neither a treadmill nor an elliptical machine. I found no parts for my equipment at the site you suggested. Instead, I found a large selection of parts for Stairmaster Stair Climbers at SportSmith.net.
    After removing the cogged belt, I found a couple of broken teeth. I cut them down a little and re-installed the belt so it spun in the opposite direction as a temporary fix while I wait for my new belts to arrive in the mail. The machine now works smoothly with the interim fix.
    President:
  • 832 Answers
I would inspect and change anything that is worn call Nation Gym parts @ 1-800-496-7278 or go to Gymparts.com,then go to Parts click on to Stairmaster you will find kits to replace all movable parts for your unit.
Posted on May 29, 2010
  • John Mazmanian
    John Mazmanian Jun 01, 2010
    I appreciate your feed back even thought stepper repairs have dwindle down to a trickle in comparison to other cardio equipment, but National Gym Supply does have an array of Stair Master parts (individually or in kits) comparable to Sport Smith depending on parts availability, I have used both as a secondary sources. Also on geographical note NGS is closer to me and I get my parts the next day without extra charge. Good luck to you in your repairs
    Regards
    MAX TREADMILL
Petal does not return like it should on tectrix climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I would suggest checking the the drive clutches on the transmission assembly. If they are not free spinning as they should, the pedal will not be able to return all the way up.
Sep 10, 2015 | RTO Tectrix Personal Stair Climber
Where can I get a power supply for my Free climber 4400cl stepper
At Sportsmith of course :) http://www.sportsmith.net/productsearch.aspx?dsNav=N:11167
if you need any help please do hesitate to call on us at 888-713-2880 or chat with us online; on the site! We look forward to hearing from you.
Aug 24, 2015 | Stairmaster 4400CL FreeClimber Stepper
Stairmaster left pedal clanks
The "clunking" you are describing is more than likely caused by either a faulty left drive sprocket, the drive shaft or a combination of both. The drive sprockets are equipped with a needle bearing type clutch. When they fail, the clutch does not grab the shaft and drive it correctly. You may just need to replace the left drive sprocket. In some cases you will need to replace the sprocket and the drive shaft.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Sep 30, 2013 | Stairmaster Exercise & Fitness
Stair master 4400cl Stepper making clunking sound user pedals when stepping
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Apr 03, 2012 | Stairmaster 4400CL Stepper
Grease used for StairMaster 4400CL to fix grinding sounds
There are several types of grease that can be used for this machine. You can use a lithium grease on the hub and a 30 WT motor oil on the chains.
Super Lube with Teflon 16 Oz Jar SPORTSMITH net
Jan 15, 2012 | Stairmaster 4400CL Freeclimber...
Stairmaster 4400pt seems to have a slipping chain.
You can take the covers off and see if it is indeed the chain that is slipping, but in most cases, the drive sprocket is actually what is failing. The following link will take you the item that should rectify your issue.
Nov 04, 2010 | Stairmaster 4400 PT Stair Stepper
Ihave the stairmaster4400CL and it does not have any resitance. How can I repair this
investigate the status of your battery. without proper power, you cannot get resistance. The machine has a 6 volt battery. the battery should provide a minimum of 6 volts when in an idle state. meaning without any activity on the machine, a cold battery test should provide a minimum of 6 volts.
Sep 23, 2010 | Stairmaster 4400CL Stepper
My Tectrix Stairmaster Personal Climber is clicking very loudly every time I work out. Is it the chain or something else? What do you recommend? Thank you.
I would take the cover off and inspect the drive chain to see how much play you have and also check the sprocket to see excessive wear. You can call Cybex International @ 1-800-677-6544 to order parts you will need the serial number that is located in front of the pedals their is a sticker with the serial number on it!
Apr 07, 2010 | RTO Tectrix Personal Stair Climber
Stairmaster 4400cl manual where can I find it, i need to find the battery in it as it seems flat... Thanks Gab
This link will take you to the parts listed for the 4400CL:
Stairmaster Stepper 4400CL Parts Spring Chain Battery SPORTSMITH net
Right above where is shows the number of results found, there are 3 tabs: "products" "manuals" and "diagrams".
Jan 22, 2010 | Stairmaster 4400CL Stepper
Stairmaster 4400cl has two problems
you need a plug to charge it. it does have a battery
Jan 12, 2009 | Stairmaster 4400CL Stepper
Stairmaster 4400CL Stepper Logo
301 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
