Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Got the Endura 30 from my wife for Christmas. Hooked it to the boat,a 12 foot MirroCraft and tested with battery and overall check, looks good so far. First time in the water on Monday, May 24, made it 30 feet from the dock and suddenly wasn't moving. Checked unit to find the prop, nut, etc, GONE..Called Minn Kota and they told me this is not covered by warranty. ??? Not happy at all. This was a result of there product not being assembled properly but now I have to fix it?? Will never buy another Minn Kota product again and will file a complaint with whomever will listen.. Andrew Farkas andrew_elsie@hotmail.com
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Have you called the dealer or returned to the store your wife bought it from. they should be the ones to warrenty the motor. if she bought it used then you need to buy the necessary parts from a suitable store and move on. minn kota is a good company and they make a good product. i do understand your frustration. you might ask for a manager at minn kota if your wife brought it new and she if you can successfully get a better answer on an appeal. good luck.
Posted on May 31, 2010
Need to know how much weight i can put in a mirrocraft 14ft boat
www.mirrocraft.com/boats/mirrocraft/simplyfishing/utility-v-series-fishing-models/
www.nadaguides.com/boats/1984/mirrocraft-northport-inc
there should be specs on the NADA site.
Aug 31, 2017 | Boating
I want to mount my endurac2 on the back of my boat but the handle an the prop are in the same direction is it possible to turn one or the other
Not entirely sure with your model but it is possible to take the head off (where the handle is) and spin that 180 degrees. You may also check an aftermarket prop that has opposite blade direction. So where normally it's on the front of the boat, pulling through water it's now pushing the water when moving to back of boat. Shouldn't be hard to locate
Apr 04, 2013 | Minn Kota MinnKota ENDURA C2 30 30"...
2005 Ford Freestar SEL battery light coming on
take it to an accredited auto electrician for a charging system check including the voltage regulator and wiring conditin
at idle the battery voltage will be 12-13 volts and at 2000 rpms it should be steady at 14.5-14.8 volts dc
Apr 05, 2017 | Cars & Trucks
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
I cannot get the front light and or back light to work.
Well you need a voltage tester for automobiles or 12 volt systems. The black wire should be hooked to a good ground. Test the wires on the back of the switch for your nav lights. If you have voltage there then you should test each of the light sockets. If you have voltage at switch but not at the light sockets then you need to trace the wires and find a bad spot or replace them. If no power to light switch you need to identify the hot lead (positive) and try to trace it back to the battery. Somewhere there should be a fuse. Need to test the fuse. An ohm meter would be handy to use in troubleshooting this. You not only need to ensure that the positive lead is good but the ground lead also. I"m not sure what kind of boat you have but for instance if it is fiberglass then the boat can't act as a ground. A seperate ground wire has to be run to both lights as well. I'm guessing since both lights don't work that the problem is between the battery and the switch. There almost has to be an inline fuse somewhere. Don't rely on just looking at the fuse. Sometimes they don't look burnt but are. Check the fuses with an ohm meter.
Nov 06, 2009 | Boating
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
423 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
