Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Cub cadet cuts out unless with full choke
Mouse ate through plug wire. Replaced sprk plg & ignition coil(one piece). Didn't know 2 gap @ first n ran engine 10 secs. or so. Then gaped to .007 n tightened. Now won't stay running without full choke on. Managed to cut lawn but not running right...any ideas? Replaced fuel filter(previous one on backwards),also replaced spark plugs, but put old ones back in. Still have to have choke out fully to stay running...help!
    Brigadier General:
  • 4,088 Answers
Use a thin business card to set the module to flywheel magnets gap--rotate the magnets under the module poles, insert the card between the poles and magnets, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the wheel to remove the card. Rotate the wheel one turn and make sure the gap doesn't close up at any point. The spark plug gap is 0.020". Having to keep the choke closed to make it run implies that the main jet in the carburetor is plugged or if adjustable, the setting is too lean. Make sure the air cleaner is not plugged. Turn the jet screw CW to stop (lightly), then back out 1-1/2 turns CCW. If this helps, you may turn it either way until the engine runs smoothly without any choking required after warm-up. It it gets better, but still not running correctly, you may have to disassemble the carburetor and clean it with spray carburetor cleaner. Hope some of this helps!
Posted on May 28, 2010
  • drallim Jun 13, 2010
    The header says that this is a McCullough saw, but your text implies a 4-stroke lawn mower engine. What is the actual engine and who made it? In the first part of your text, you replaced one spark plug wire/module. In the latter part, you say that you replaced multiple plugs, but returned the originals. What does the carburetor and fuel tank look like? We need to form a mental picture of what you are working with to be able to offer better advice. Good luck!
I have a cub cadet RZT54 zero turn. Last year the choke would not close and had to do it manually had that fixed. This year the choke will not open unless you do it manually. Hard to do for one person
I've seen this before and replaced the wire wrapped cable with a different type cable (plastic/steel reinforced) and that solved the problem. Hope this will help.
May 29, 2017 | Cub Cadet Garden
There is a flashing symbol- black rectangle with two white triangles one on top of the other mower stops but will restart after a few minutes. Cub Cadet LTX-1050, v twin1 Hydrostatic
Make sure air filter is clean or replaced. Check oil level. Change oil if not done this year. Remove plug, clean and gap. Ensure gasoline isn't over 30 days old and use a gas stabilizer if gas cap isn't marked E85.
Jun 18, 2016 | Cub Cadet Garden
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Engine does not start. Starter & solenoid work fine. Checked air filter, fuel filter, fuel level, level in choke position. Plug is kind of flooded. Increased plug gap slightly. There is no spark....
Most small engines use a flywheel with a magnet embedded in it and an ignition coil with a core that sits a few thousandths away from the flywheel. Ignition coils are common failures probably because they come from our wonderful Chinese friends. They have demolished all US manufacturers. If you replace the coil, use some gauge to measure the gap between coil core and the flywheel magnet surface before removing the old coil. Otherwise you may spend a little time using trial & error to get the engine running again.
If your engine is a Briggs and Stratton, you can find very complete maintenance downloadable information on their website. This will pertain to the engine only, not the mower.
Dunno about Tecumseh, haven't had much need for service info on those.
Jun 30, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
The mower is a cub cadet it usually runs fine until warm and will die start idling up and down and then die every now and then pop like back firing.it will start right back if you lift the choke i changed...
I had the same problem , found out it was the coil was getting hot. I replaced the coil which was not hard , remove 2 screws an unhook 2 wires. You have to get the coil from a dealer , in my area anyway. Hope this helped.
Apr 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
186 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
