Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
Heater Wont light
Just opened pool and trying to get heater going. I can here the electronic ignition clicking, but pilot not lighting and furnace not turning on....
  • 990 Answers
If it has been off for a while you probally just have to bleed the gas line out. Shut off the gas valve at the heater and then open the union at the heater. Turn the gas back on till you can smell gas. Shut it down and close the union then turn the gas back on and try it again.
Posted on May 28, 2010
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
Heater doesn't come on?
The electronic ignition system in a gas furnace is a modern development that allows more reliable performance than standing pilot furnaces, provides energy savings and contributes to better furnace efficiency (AFUE). With a standing pilot, found most commonly on older low efficiency furnaces (55% to 65% AFUE is not uncommon), a small gas flame is always burning and is known in the lexicon of American home repair as a "pilot light". The problem with this type of "analog" ignition is that it wastes energy by constantly burning gas and can sometimes be unreliable. These issues have led to the development of electronic ignition systems for mid to high efficiency furnaces that exceed the U.S. government's established minimum AFUE rating of 78%. The electronic ignition occurs typically in one of two ways:
  • Intermittent Pilot, or
  • Hot Surface Ignition The intermittent pilot system uses an electronically controlled high voltage electrical spark to ignite the gas pilot and then subsequently the main burners, when the thermostat calls for heat.
    The hot surface ignition system uses an electronically controlled resistance heating element not unlike a light bulb filament (and shown in the photo above), to ignite the gas burner.
    It is important to understand some of the other components of a modern furnace that you will encounter depending on the type of high efficiency furnace you have. Why? Because they can also come into play in repairing an electronic ignition furnace when it won't run properly. Let's take a quick review of the types of furnace designs and components found in high efficiency furnaces using electronic ignition.
  • Nov 14, 2010 | Goodman GMS90703BXA Heater
    Gas Furnace Will not light
    Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
    Shastalaker7
    Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
    No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
    not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
    Oct 31, 2009 | Dayton Gas Furnace Heater
    Gas wont ignite
    unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
    Feb 23, 2009 | Coleman Propane Forced Air Heater...
    Pilot light will not light
    Sounds like you may need a new electronic control module. This is a rectangular shaped plastic box that has wires coming out of it. This is what tells the pilot to light on these older furnaces.
    Jan 25, 2009 | Honeywell L4064B2236 Fan/Limit Control...
    Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
    464 people viewed this question
    Top Rheem Pool & Spa Experts
    Steve Slater
    Scott Corey-reid
    David Spradling
    David Spradling
    Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
