Question about Sharp Aquos LC-32D40U Television
Sometimes the picture comes on then immediately goes off. Sometimes it will stay on for hours then go off. Found a bump to the upper right corner would usually work to get it back, but that is no longer working.This has been going on for years, but has recently become a major problem. Evidently Sharp does not acknowledge this problem but many on line people have experienced this.
  • 4 Answers
Turn the power off. grab the uperr left and right hand corner of the tv, gently flex the tv back and forth. turn on tv
Posted on Sep 05, 2010
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Blower is not staying on. When I start the truck it will come on for 1 or 2 seconds then immediately cuts off. When it cuts off, I can turn the ignition off and then back on and its the same thing....
The blower motor is most likely the problem.When it goes off,bump the blower motor with your hand to see if it starts back,if it does,the blower motor is bad.
Feb 15, 2011 | 2004 Dodge Ram 1500
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Photos have a black corner. Sometimes upper right, sometimes lower right. The black corner covers approximately 5% of the width and height of the image. Can I fix this myself?
This might also come from a problem with a dealignment of one of he servo-motors (horizontal or vertical) which center the lens during anti-shake adjustment.
If your camera vibraets at start or shows a vibrating image on display then this is the problem.
Then the lens is often out of axis and black corners appear on the display and of course on the picture...
I have not found the solution but have posted a request !
It may only be some disconnected part near the lens but unfortunately nobody shows pictures of HOW to dismantle the Z5 ! and WHERE are these 'bloddy' servo-motors or alignment devices ?...
Sep 14, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
The TV has a Black cloud on the right half of the
My parents have the same issue with their Sony KDL-46V4100 TV and were told by the tech that the LCD screen was physically broken and would have to be replaced. The replacement of the screen would cost more than a brand new TV and the TV is not longer under warranty. After the TV is on for awhile the Black cloud goes away but it always comes back when they turn the TV off/on. It stays for 20 - 30 minutes sometimes. The Tech took both top corners of the TV and pushed one back and pulled one forward to show them he could recreate the problem after the black blob cleared up. By twisting the corners he made the blob reapper which he claimed was becuase of the damaged screen. I have no idea how the screen was damaged? I helped them take it out fo the box and set it up. We never dropped it bumped it once? It's never falled off the stand so go figure? It would be nice to find more people with this issue and get a recall going. Something that expensive should last longer than to two years.
Jul 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
When watching a dvd, screen goes black and the word video appears on the screen in the upper right hand corner. Picture sometimes comes back, and then goes out again.
It sounds like your TV/monitor is losing the video feed. That's why it displays 'Video' - the label assigned to the input - so you'll know the TV is turned on but missing the input. You would get the same response from the TV if you turned the DVD off. I'd look at the integrity of the video connection from the DVD.
Jan 19, 2010 | Audio Players & Recorders
Upper left corner is green
Check the mirror in the TV..may have come loose.
Sep 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
My sd-582hd5 picture goes black
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
