Question about Black & Decker MX55 PowerPro Hand Mixer
GE Hand mixer, D1M24, 420 A, nylon interior gears are stripped. Any replacements?
5 Suggested Answers
  • 41 Answers
SOURCE: My west bend hand mixer (model # 41015) blades do not turn
your unit is not worth repairing parts will be very hard to get this unit is usally a throw away unit
Posted on Dec 11, 2008
SOURCE: Power cord for GE hand held mixer
I have a gold mixer also, My wife loves it. The cord went
and was unfixable. I found one on this website abtecparts.com.
The cord was $5.99 plus shipping. Good Luck
Pat
Posted on Aug 02, 2009
SOURCE: I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Posted on Nov 26, 2009
SOURCE: Replacement Beaters for GE Hand Mixer
I realize this is way way late, but I found this page trying to find this information myself. I found the answer so I wanted to solve this problem for the next person who is looking. I ended up having to contact Hamilton Beach, at 877-539-0225, to order this part. The GE people (www.gehousewares.com) only do the newer stuff that is still covered under warrantee. It took a number of calls and e-mails to get this information, but it finally got this info out of them. I now have my beaters.
Posted on Mar 02, 2010
Speed problems with kitchenaid artisan mixer.
It sounds like two issues, the first is going to be the phase board, you will need to replace it, that should fix your speed issue.
The second issue will be a stripped gear, in that mixer there is a nylon gear that commonly goes bad, that would be the worm gear.
Here is a link to the phase board: http://www.mendingshed.com/kaphaseboard.html
Here is a link to the worm gear:
http://www.mendingshed.com/kawormgear.html
Also here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
The service manual will show you how to take apart the mixer, and put it back together.
Jan 31, 2014 | KitchenAid Food Mixers
Nylon gears stripped on hand mixer beater gears
Unfortunately, modern small appliances are considered "disposable" by the industry. So there are no "better made" parts. The best you can hope for are the same as what was originally installed. Try https://www.ereplacementparts.com
Dec 29, 2013 | Black & Decker MX50 PowerPro® Mixer
Kv25g0xbu
Back cover off, pedestal off, planetary off and then undo all the gearcase screws. Two wires need to be removed from the speed control plate too, 1x white, 1x black. You can then split the gearcase apart and change the gear. Planetary and nylon gear are both held on by pins that need to be punched out with correct size punches, both different.
Dec 22, 2013 | KitchenAid KSM50PR Professional Series...
Mixer noisey and not going round freely
Your mixer most likely has a stripped gears, or a combination of stripped gears. The 5kpm5ewh is an international model similar to the ksm5. The gearing inside the mixer will be the same, some of the electrical parts may differ.
Your mixer has a nylon worm gear inside, this is the most common gear to strip inside the mixer. I would recommend opening the mixer and inspecting all of the gears before you place an order.
Most likely you will need the worm gear, which is available by itself (http://www.mendingshed.com/kawormgear.html) or you can get it in the whole worm drive pinion gear assembly (http://www.mendingshed.com/kitchenaidgearassy.html) the whole assembly is a lot easier to replace, and will save you a lot of time. You may also need to replace the grease inside your mixer, KitchenAid recommends the Benalene 930-2 food grade grease, it is only available in a 30oz can (http://www.mendingshed.com/kagrease.html) And you will also need to replace the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To aid you in your repair, here is a link to the KitchenAid service manual (http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf) This will walk you through how to take apart the mixer, replace the gear, grease and gasket, and reassemble the mixer.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
THE MENDING SHED, HELPING YOU GET THE JOB DONE SINCE 1971.
Apr 09, 2013 | KitchenAid Pro-Line Heavy Duty Lift Bowl...
My motor doesnt seem to go round freely
Does the beater shaft turn when there is no load? (bowl is empty) Or it will not turn at all?
It sounds like you have a stripped gear. Your mixer has a nylon/plastic gear inside the mixer and that is 99% of the time what goes wrong. You will want to open the mixer up and inspect all of the gears, but most likely you will need to replace the worm gear, part number W10112253.
Here at MendingShed.com we sell Genuine KitchenAid parts and the items can be found on our website.
Here is a link to that gear: http://www.mendingshed.com/kawormgear.html
You may also want to replace the grease and gearbox gasket while you have the mixer opened up.
We also have a service manual posted on our website which will aid in taking the mixer apart and putting it back together properly.
Service Manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 09, 2013 | KitchenAid Food Mixers
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
What is the best stand mixer to buy for home use? My 4 yr. old Sunbeam Heritage Series 450 watt Mix Master has stripped beater gears. Before that it wouldn't tilt back because of a loose screw. I don't...
the best stand mixer is a hobart n 50 its a little expensive, but if you use your mixer all the time, its worth the investment, buy 6 to 8 sunbeams, or kitchenaids, to 1HOBART N 50. metalgears in transmission, and in planetary,all the others have nylon gears
Jan 16, 2010 | Sunbeam 2351 Legacy Stand Mixer
Grain mill stops turning
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
May 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Dec 10, 2008 | West Bend 41036 Mixer
Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
Sep 13, 2007 | KitchenAid 32685 Mixer
Black & Decker MX55 PowerPro Hand Mixer Logo
347 people viewed this question
Top Black & Decker Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Black & Decker Food Mixer Expert? Answer questions, earn points and help others
