Question about GE Monogram® ZET1058 Electric Double Oven
ZET837SB3FS what are the cutout dimension - GE Monogram® ZET1058 Electric Double Oven
    President:
  • 949 Answers
Here is a link to the dimensions that you will need.
GE Installation
Posted on May 28, 2010
What are the dimensions of the space required to install an Omega Europa 20-1 oven under a bench
installation dimensions are included on the brochure of the unit
the brochure will be available from a retailer or on line and those dimensions are what builders use to make the right sized opening
Sep 09, 2016 | Ovens
I'm removing this Whirlpool oven and want to replace it with a KitchenAid Model KEBS109BSS. Will the new KitchenAid fit in the existing cutout?
Just fill in the old opening on the top with styling to meet the height needed. If the new one is narrower in width add equally to both side styles, if its wider trim equal amounts off both sides.
Nov 05, 2015 | Whirlpool Ovens
What are the cutout dimensions of a Magic Chef 59GN?
Need to find out what size oven to buy to replace Magic Chef : 59GN -5TVW
May 25, 2013 | Magic Chef Ovens
Power to oven lights but not to cook top or oven. checked pigtail and breaker, both ok. Thermal cutout?
Yeah sounds like a Thermal cutout to me ... do you have 120V on both sides??
Mar 23, 2011 | Ovens
The oven keeps turning its self off
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Mar 06, 2011 | Stoves 720EF Electric Double Oven
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Our electrolux eob5630 oven keeps turning off
its the thermal cut out. replace it. ISOLATE oven.
slide oven out a few inches, remove knobs, remove front panel(two screws)
you will only be able to pull panel 3-4" due to wires.
Cutout has 2 blue and 2 white wires..
you may need to snip a couple of cable ties.
Put new cutout in one wire at time( easy to forget where they go)
Tidy up wires. Put cover back. Secure oven in hole.
Turn on power. Reset clock(otherwise won't work)
Done 10 minute job
Jul 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Nov 13, 2008 | GE Ovens
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
GE Monogram® ZET1058 Electric Double Oven Logo
270 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
