Konica 7030 IP-011 - 64 bit printing
Konica 7030 IP-011
There are no 64 bit drivers yet I need to print from a new laptop containing a 64 bit version of Windows 7. I can't seem to get any drivers from older versions of Windows to work.
Is there a way to ''print through another PC'' which is running an older version of Windows?
5 Suggested Answers
omerboo
  • 424 Answers
SOURCE: the Windows 7 driver for the HP deskjet5650 does
Driver download link: HP Deskjet 5650 Color Inkjet Printer Driver
Posted on Feb 03, 2010
  • 2666 Answers
SOURCE: the canon lpb 2900 printer driver l downloaded is
You cannot "make" a driver work with a system it is not designed for.
It maters not which version of Win7 you have, if you don't have the correct drivers it will not work.
Posted on May 07, 2010
Testimonial: "l have resolved the problem. I think our responses to issues or problems should be encouraging and discouraging after all there is no impossibility in the IT world. In other word, lets do a thorough research before responding to issues raised. Thanks"
SOURCE: print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Posted on May 20, 2010
  • 1218 Answers
SOURCE: Looking for windows 7
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
Posted on Nov 25, 2010
WHERE CAN I FIND A USAGE REPORT?
press the star button to print that info press print on that page
May 28, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Konica minolta biz hub 250, causes all applications to not respond for about 1 minute every time we print from a machine with windows 7 64 bit pro. Got the latest window 7 64 bit driver, printer works...
Might have a KMBS tech come out and update the copiers Operating system (Firmware). Driver is for the computer firmware is for the copier which is located on a secure server KMBS wishes to protect its printing software
Apr 29, 2017 | Konica Minolta bizhub 250 All-In-One Laser...
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
I install konica bizhub 350 to my network. scanning is going to SMB and very nice, but when i want to print from my PC, it did not print and also give no error.plz immediate help necessary. envoirment is...
Reinstall print driver to the PC using same ip address and print test print. next the same procedure go to web browser enter the ip address and choose administrator and the password 12345678. all your question will be in that area. scan, printing and network.
HH
Aug 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printer status offline
It sounds like the print driver is not playing nice. Try removing the printer and uninstalling the driver from the DRIVERS TAB found in the PRINT SERVER PROPERTIES menu. Then reinstall the printer using OLDEST drivers (version 1.0) usually on cd that came with the unit.
Jun 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica 7030 tray # 4 code
You should contact Konica/Minolta for that information. That requires an tech engineer from K/M to fix that issue if it is possible to do or support.
Jun 11, 2008 | Konica Minolta Office Equipment & Supplies
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7145 PRINT DRIVER
The Konica Minolta 7145 have two different companies that made the print controller. If you have an older KM 7145 then you need the old Peerless Legacy driver. It's not on KonicaMinolta's website. You can use HP 5Si driver, but you won't have and of the options (ie finisher, fax, lcc).
Mar 14, 2008 | Computers & Internet
1,521 people viewed this question
jasbo
jasbo
