Question about Kenmore 22642 Top Load Washer
How to install 3949238 in kenmore model 110.26912691. I have unscrewed the control panel, but the brass hinge wont come out
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer;
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
In order to replace the "dial" you have to release the console by snapping off the two end caps, unscrew the two phillips head screws, and pull and lift the console.
It should lean back and balance on the hinges.
To release the dials from the timer, you may have to hold the metal shaft on the back of the timer with a thin needle nose pliers while you un-screw the knob.
With the knob off, the dial simply pulls off.
Posted on May 28, 2010
Model 106.66862790. How can I replace defrost timer?
The defrost timer=> 2193084 Defrost Timer is found inside the controls panel inside the fresh food compartment see item location in photo=> HERE Turn power off by removing plug from outlet lower control panel unscrew timer and disconnect the plug attached to it. Install timer and wiring and close the control panel cover tighten the screws that hold the panel in its place
APPLIANCE911
Jan 30, 2016 | Kenmore Refrigerators
Kenmore elite stackable wont spin and drain
You will need to replace the lid switch.
Here is a link to the part you need.
You should not need any special tools. Unscrew the panel above the lid, then use a screwdriver to pop out the two brass clips that hold the top down and take off the top. That should do it.
Oct 13, 2012 | Kenmore Washing Machines
I have kenmore 110.26912690 washer. I want to remove and replace the water intake valve and it seems I nearly need to take the whole machine apart. Is this so? can you send me the how to get it out and...
The washer comes apart very easily. Problem is how the control panel is released. Either there is two screws in the front or rear of the control panel once these are removed the panel pulls forward and leans back. On some models there is two clips under the front edges of the panel which have to be depressed with a putty knife. On some models the end caps on the control panel pry off exposing the screws. After leaning back the control panel you must un-plug the lid switch, remove two brass coloured clips holding the case to the rear panel by prying with a screw driver, lean the case forward and remove the case.
Feb 26, 2011 | Kenmore 24042 Top Load Washer
How do I get the lid off of kenmore washer 110-24872300.
Remove the 2 end caps on the control console.
They snap off.
Remove the 2 screws on the right and left front of the console.
Lift the control console to the rear of the machine. It is hinged.
Use a flat blade screwdriver to unhook the 2 brass clamps holding the cabinet to the rear panel.
Unhook the lid switch wire harness.
Pull the cabinet forward to remove it from the base.
Reverse this procedure to re-install it.
Jun 25, 2010 | Kenmore Washing Machines
Lid Switch
HI, The part# is 3949238. There are two ways to replace this switch. The easiest is to remove the two screws holding the lid switch. Pull the switch out enough that you can clip the wires at the switch. Cut the harness off of the new switch leaving enough wire to put wire nuts on connecting them together.
The other way to change the switch is to remove the cabinet. Here is how:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can see the lid switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
How do i take the outside off of my kenmore washer to check the motor stuff,
kenmore/whirlpool & heaps of others
  • Unplug washer
  • turn off taps
  • remove trims from edge of control panel
  • remove screws from under bottom edge of trims
  • raise slide forward and flip control panel over, hinged at top, do not dislodge air hose to level control
  • remove brass body clips under control panel, not position for reinstall
  • lift body 1/2inch (locator studs at bottom) and remove, top front and both sides come away as one piece
motor pump gearbox tub suspension is now exposed
Sep 07, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
Aug 29, 2008 | Washing Machines
Kenmore 22642 Top Load Washer Logo
347 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
