Question about Whirlpool Duet GHW9150P Front Load Washer
Dryer will not heat up
Whirlpool duet
  • young4 Apr 07, 2008
    dryer will spin but no heat checked vent no clogging breakers everything is on.
My dryer gets warm but not hot, it takes lnger for the close to dry. what may be wrong
Posted on Mar 06, 2009
  • 5,911 Answers
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. Make sure the dryer is UNPLUGGED. The Duet has screws under the bottom edge of the lower panel that you need to remove. Simply remove the screws and the panel drops down, then off. Sometimes the panel can stick. If this occurs, a slight tap on either side will free it.
NOTE: The heating circuit should also be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box on the right hand side of the dryer looking in) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box all the way to the back.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions. If you can identify a bad part and need assistance locating a replacement, let me know.
Posted on Apr 08, 2008
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Posted on Sep 13, 2007
jsrock516
  • 5911 Answers
SOURCE: no heat in whirlpool duet dryer replaced the
You have this listed under "Front Load Washer" and don't explain which type of of dryer you have (Gas or Electric). I'm assuming this is an ELECTRIC dryer, since you mentioned a thermistor. The following link will explain how to troubleshoot your dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The symptoms of a dryer no heat problem are, the dryer drum will still spin, the blower fan runs, and all indicators function, but the dryer does no heat. If this is the problem you are encountering, then the link I provided for you should help you find your cause.
The first step to troubleshooting this problem is to check the voltage at the wall receptacle across the two hot leads (the two large slots in the receptacle - each leg to neutral reads 110-120VAC). A reading across the two hot leads should yield 220-224 VAC. If the voltage is incorrect, this can cause the heating circuits to fail, but allow everything else to work. I have seen where one leg of the 220VAC circuit is tripped or not working at all and causes the wall receptacle to read 1/2 the normal voltage that is required. This could be a problem with the circuit breaker panel or wiring in the wall receptacle. The heating circuits require 220VAC to operate, while the controls and drive motor only use 110-120VAC. If the voltage is correct at the wall, check the voltage at the terminal block in the back of the dryer. This is where the power cord attaches. If the voltage is correct at the terminal block, the problem is in the heating circuits. If the voltage is not correct at the terminal block, you may have a bad power cord.
NOTE: Please ensure you UNPLUG the dryer when replacing any internal components. Dangerous voltages are still present with the unit turned off.
Now...what controls the heating circuit in a Whirlpool manufactured dryer is the Thermal Cut-Out (TCO), the Hi-Limit Thermostat and the Heating Element. I'm assuming you replaced the TCO(?). If you did, it is recommended that you replace the TCO along with the Hi-Limit Thermostat. Failure to do so can result in premature failure of components you may have already replaced.
The link I provided explains all this. Please read through the information I provided and let me know if you have questions. If you require further assistance, please let me know before you rate the solution. I hope this helps you resolve your problem.
Posted on Feb 27, 2009
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
My whirlpool duet gas dryer will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
How do I replace heating element in a whirlpool duet dryer?
The following link explains step-by-step how to replace the heating element on a Whirlpool Duet series dryer:
http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element
This is not a difficult repair, but it can be tedious. Just follow the instructions I provided and let me know if you have any questions. I hope you find this helpful.
May 17, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Jan 17, 2010 | Whirlpool Dryers
MY DUET DRYER IS NOT HEATING UP. WHAT COULD BE THE
no heat at all probally element or the thermostat on the element.if heats but takes long time outside venting probally plugged up.make sure your getting 220 v to dryer before anything
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool Duet GHW9150P Front Load Washer Logo
453 people viewed this question
Dan Webster
Dan Webster
Sal De
