Question about Haier HD656E Dehumidifier
The dehumidifier keeps saying "low humidity" and then shuts off. I don't think this is accurate. It is very humid outside and the basement feels very humid.
  • 420 Answers
You need a new hunidistat for it.
Posted on May 28, 2010
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
May 16, 2011 | Frigidaire FDF50S Dehumidifier
Unit runs but doesn't collect water and there is a lot of water in the basement. Have had dehumidifier for two weeks and was working well before.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. Also, it's not uncommon on some dehumidifiers for the fan to almost run constantly. It's designed to keep the air moving, in a effort to detect when the humidity level rises.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter no is the time to check and clean it. And while your at it, clean the cooling coils too. Since it sounds like this unit has been working hard for 2 weeks.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 15 to 25 minutes and check the water collection bucket. If there's water in it, it's working as it should.
For more information on the proper operation of a dehumidifier, go to the Tips section of Fixya and look up "Taking the confusion out operating a dehumidifier".
Hope all this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Dehumidifiers
Whirlpool dehumidifier in basement has stopped taking water into
how warm is the basement,if the temp of the basement is lower than say 70 degrees,the unit will not function,true dirty coils can have this effect also and a refrigerant leak on these will cause the same result,if the temp is low,use a fan to move the air and this will help with your humidity problem too
Apr 02, 2010 | Whirlpool AD35USS Dehumidifier
My 320 is powered up and running but is not collecting any moisture
low outside temp means low indoor humidity
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 22, 2009 | Amcor MD250 Dehumidifier
My challenge dehumidifier runs ok but does not collect any water , whats the problem?
low outside temp means low inside humidity
Dec 20, 2009 | DeLonghi Dehumidifiers
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Edison Dehumidifier
You didn't say what humidity range you have it set for, or how damp of an area it is dehumidifying. The one in my basement also never shuts off and we have it set for the lowest humidity (meaning we don't want any down there). If you think it should be shutting off you might want to get another Humidistat they are $33.05 at this link, http://www.appliancefactoryparts.com/search/partinfo.php?partsID=278698&modelsID=118670&typeName=dehumidifier
May 19, 2008 | Edison Dehumidifiers
Haier HD656E Dehumidifier Logo
282 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
