Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
What is the spark plug gap?
Is there any other adjustment that I can make that will make starting easier - right now it takes about 10 vigorous pulls to start?
  • 284 Answers
.030 on the plug gap
Most carb. have a diaphram made out of rubber under the carb. REPLACE IT. and thank the ethanol fuel for the cause
Posted on May 29, 2010
Do you have to remove the engine to replace the distributor on a 1994 Acura Vigor with the 5 cylinder 2.5 liter engine
Here's a video to check out,but your motor doesn't come out for the distributor,this video may be your problem,pull your plugs and see if they are oily. Acura Vigor common problems
Aug 16, 2015 | 1994 Acura Vigor
My 2004 suzuki volusia VL800 cranks but won't start. I checked the fuel pump and it pumps fuel.I checked for sparks and it sparks. what could be the problem?
I always go back to the basics. Fuels, spark, compression. Try a shot of starting fluid spray into the carb immediately hitting the starter, if it starts and dies the problem is fuel. If it doesn't even spit or try, it's ignition. Gasoline nowadays is poor, shelf life maybe 3 months. Use absolutely fresh non oxygenated (10% ethanol) premium. Spark plugs can fire out of the engine easier than when under compression. I use a dandy home made tester, a spark plug attached to a battery clamp which easily grounds to the engine. Use a healthy .050 gap to see the spark is strong enough to jump the distance. After you try to start it, pull your plug. Is it bone dry or wet? That'll give a clue. If all else fails it's time for a compression test, and determine if your spark is happening at the right moment. Re try your efforts first as described, get back to me with your results, and best of luck.
Feb 11, 2015 | 2004 Suzuki VL 800 Volusia
1968 Ford Ranchero
Spark Plug Gap is .032 inch. Many have started using .035 as it is easier to set using most newer tools.
Point Gap is .016 inch. You may also set point gap by using a dwell meter if you have one. That setting would be 32 degrees.
Aug 01, 2014 | Lisle 67870 Spark Plug Gauge Gap
CHECK COIL ON WEEDEATER
Most likely the isue is too large plug gap. The proper gap is 1mm, set the gap first then if you still want to check coil output take the plug out hold the base of the plug to the cylinder head pull the start rope and look for a spark. If you can't see a spark seperate the plug base from the cylinder with your finger pull the cord, if it hurts stop pulling the coil is good! If you dont feel the shock then the coil may be defective however there is a couple of electrical conections to check first. If you already have access to the coil and have an ohm meter check for a low resistance (below 10 ohms) across the coil wires.
Nov 04, 2012 | Garden
Brand new, seems like everything assembled fine. Won't start. Right gas mix, right chain saw oil. No start. Makita dcs 400.
remove the chain and bar and try to start without it, if it start then chain was too tight. also you may need to do a small adjustment to carburator. check spark plug gap. check for spark. even brand new one need an adjustment at first use. if you can not make it start it has warranty. take it where you bought it.
Feb 09, 2011 | Garden
How to set points
Remove spark plugs to make engine easier to turn over.
Rotate engine until etched line on points cam lines up with the rubbing block on one of the points.
Set gap to .015"
Rotate engine 180 degrees and repeat.
Reinstall spark plugs.
Hook up timing light to left hand spark plug (cylinder #1)
Start bike and hold throttle about 2500 RPMs.
Shift point breaker plate left/right until timing marks align.
Hook timing light to #2 cylinder.
Run @ 2500 RPM.
Adjust remaining point sub-plate (on main point plate) until sceond timing mark aligns by timing light.
Sep 08, 2010 | 1973 Triumph T 100 R
How do I change the plugs on my 2002 jaguar x-type 2.5 v-6?
Disconnect the negative battery cable. Then start at the front of your engine. Pull the spark plug wire off the spark plug from the boot that covers the spark plug. Remove spark plug from engine block, take new spark plug, check for proper gap and adjust if necessary, and then install new one into block. Repeat for the rest of the plugs. Re-connect negative battery cable and you should be good to go.
Jan 29, 2010 | 2002 Jaguar X-Type
Honda 650 2002, starting problem
Hi there and thank you for using FixYa!
Yes this is a common problem with bikes having dirty spark plugs and poor fuel quality. What you do is to remove the plugs, clean it well.. or better, replace it with a new one. Then if it still doesnt start, pull the choke knob for a while. start it.. if it still doesnt start. Open the carbs to check if there are any dirt blocking the jets. Blow the holes with compressed air. Assemble and replace it back. Start. if it still doesnt work, check for the cable, make sure it has current firing to the spark plug.
let me know if this helps..
Mar 23, 2009 | 2001 Honda Vigor FX 650
Poulan Pro 36cc won't start
Spark should jump at least 1/8 inch gap.You would need the correct coil for the application spaced at 10 to 12 thousands inch.
You might unplug shutoff wire and try,it might be shorted a lttle causing weak spark.
Feb 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Spark problem
maybe when you are pulling the wire just a little you are making a better connection, make sure your wires are all in good shape, it may be just loose
Nov 20, 2008 | 1989 Suzuki Rg 400
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
202 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
