Question about Maytag Neptune MAH5500B Front Load Washer
Light out but light bulb still works
The light bulb still works but does not light when the door is open causing the whole machine to not work unless I trip the breaker. Thoughts?
  • 10,319 Answers
HERE is a trouble code chart for your machine
If the breaker constantly trips, the unit has a short & possibly no codes will come up for this reason
I would check the circuitry for plug in cord first to the washer for a possible loose connection
http://www.applianceaid.com/neptune8.html
Posted on May 29, 2010
Door works but lights will not go on and bulbs are good
The contact tab in the socket is bent downwards. Disconnect the opener and pull that tab upward enough with your finger (it won't zap u unless you forgotten to unplug it!) So that when you screw the bulb in it will make contact with the bottom of your bulb. Or you may have a loose connection inside the motor housing unit. If neither of the two work it's your main logic board. Secondly if you get it to work I suggest garage opener bulbs. Their ideal for that specific purpose but any low watt bulb should be okay.
Jan 29, 2016 | Building Materials
Remote openers wont work unless inside gerage
Possible bad battery. Or there is some type of radio frequency interference coming from somewhere around your house.
Jan 25, 2016 | Craftsman Garage Door Opener 1/2 HP Chain...
Sears garage door opener wall switch works properly (I do NOT have to hold button in to close door), remotes don't work. Sensors are solid green and door reverses when beam is broken when activate
If you recently changed the light bulb in the unit, try changing it back to a basic clear bulb. I just had the same problem, and after research, found that changing bulb to a new type LED bulb messed up the remotes. A good test, is to try the remotes when the garage door light is "OFF". My remotes worked as long as the light was "OFF". I changed the bulb back to basic bulb, and everything works fine!!
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
GE model 26 we changed the bulb and light still is not working..what can it be?
try checking for a stuck "off" switch around the door or where the door latches, or could be loose wiring, Do Not open up the guts of a microwave unless you know what your doing, you can seriously hurt or even kill yourself.
May 09, 2012 | GE Microwave Ovens
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
Garage door only opens sometimes with remotes< and exterior keypad. always works with wall mount button.
Check the light bulbs in the opener. Newer fluorescent or LED bulbs can generate enough radio frequency interference that the normal signal levels from the remote will be inadequate.
Of course, make sure the remote batteries are fresh.
Sep 04, 2011 | liftmaster Garage Door 1/2 Hp
How do i change rear turn signal bulb
I just watched the service station replace the rear turn signal bulb of our 2008 Enclave in about 5 minutes for $30! He opened the tail gate door, there were two small squares in the black lighting panel trim that he popped open. Inside each was a screw that he removed. This enabled him to remove the whole lighting panel. He then twisted the bad bulb and removed it and replaced with a new one. He checked that it was working then popped everything back into place added the screws and closed the squares back up. DONE!
Sep 10, 2010 | 2008 Buick Enclave
Garage door opens and closes,light bulbs have been changed, light does not come on when door opens and closes
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light bulb socket.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener light bulbs burning out
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Mar 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Maytag Neptune MAH5500B Front Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
