Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
The machine does not work and the inside structure is stuck I can not get it out
    President:
  • 1,561 Answers
You go with the visual check first. Check on the electric cords, switches, timers, fuses, thermostats and heating elements to see if there are any damages components.
If there are some damages that are visible visually, get it replaced or repair it, if not, then you would have to dissemble the coffee maker to assess the thermal fuse.
Unplug the unit from the electrical receptacle.
Remove the carafe and filter basket. Also remove the water reservoir lid.
Turn the coffee maker over and remove the screws that secure the case. Remove the case.
Take a look at the control cavity and assess. If it is a a case of disconnected wire, debris etc. simple fix, reassemble and test. If it is not so, continue to the step 7.
Use a multi-meter to test the warming and heating elements, the switch, thermostats and timer.
For any parts that is defective, work out the costing and if it worth the while, replace it.
Reassemble the appliance and reinstall the carafe and basket.
Top up the water reservoir to 50%, then test it by turning on the coffee maker.
This should fix the problem with the coffee maker.
Take care.
Posted on May 28, 2010
  • quintanillah May 28, 2010
    I turned the Coffee maker over and there are not screws at the bottom
  • Sulaimon Jimoh Olayemi May 28, 2010
    If there are no screws as you said, it means they are cocked with each other to overlap, exact little pressure to pull apart but please be mindful of it not getting broken or damage and be rest assured there are no screws as you said in other to avoid any damage. with this, you can carry on with other procedure.
    Take care.
What are the contribution of Brijmohan Agrawal towards the construction of Hydraulic Control Structure on Indrwati-Jhora canal?
Chhattisgarh State Water Resources Minister Brijmohan Agrawal has ensured the Orissa State Government to complete the improvement of Hydraulic Control Structure on Indrwati-Jhora channel at the soonest opportunity. Agrawal said in a meeting made by the Central Water Commission at New Delhi on 31 May 2002, it was created two structures on Indrawati River and Jhora Canal and circle waters between the two States. The advancement work of the Hydraulic Control Structure as indicated by the proposed drawing layout will be done by the Orissa State Government. The advancement of structure work was apportioned to the Orissa Construction Corporation by the Orissa State.The contract purposes of interest says that the improvement work will start on 25 March 2012 and will be done on 24 June 2014. The work was late to the point that the due date was extended till June 2016.
Shri Brijmohan Agrawal Irrigation Minister said that govt Engineer Indrawati meander division Jagdalpur and his group of Technical powers together with Orissa nation reverse numbers inspected the creation webpage online on 23 April 2015. The work changed into arranged to be at a stop. It was determined that approximately 30 concerning penny water was gushing inside the Indrawati conduit and 70 as per penny water get the chance to be spilling in Jhora Canal. The brief dam have been destroyed.
Apr 18, 2016 | Computers & Internet
Tip
Attention To Solve Paper James Of Transfer Roller
Sometimes you may be able to solve the common problems yourself in your laser printer if you know a little about the structure inside it, such as paper jams due to improper positioning at the transfer roller. Before the printing process at the fuser assembly, the paper has to pass through the transfer roller inside a laser printer that is used for transferring toner from the cartridge drum onto the printing medium. It works with opposing electrical charges to pull the toner particles.
Paper jams usually occur at the image transferring process, if the paper get stuck at the transfer roller, just open up the side cover and pull out the paper gently, don't touch roller surface without gloves when hold the ends of the roller, as the sweat and oil of your hand can pollute and damage the surface material.
on May 05, 2017 | Office Equipment & Supplies
Needle shaft stuck. Machine won't work.
It's possible that you have threads wound somewhere inside the machine. Likely places are the tension unit and near the hand wheel.
Sep 17, 2015 | Singer 6038 Mechanical Sewing Machine
Have had washing machine almost a year, was working perfectly, now wants to bang and clang on spin cycle, machine is level, is there any internal adjustments that can be made
There is a concrete block which sits inside machine.check to see if the springs that hold it in place have not broken, check penny trap for blockages and don't overload machine.uneven spinning is usually down to machine spin at high speed when water isn't draining off clothes hence the weight is more uneven and causes the drum to hit against internal structure.
Oct 24, 2014 | Washing Machines
Can load floppy disk in machine
look at your mechanical structures.. maybe something is bent...
Sep 01, 2014 | Husqvarna Viking PC Main Board for Viking...
Display fill water only but water full help
check small float in tank is not stuck in the down position
Dec 29, 2013 | Jura Capresso Impressa S90 Espresso...
When in spin cycle it sounds like a bearing is going bad. It gets louder and louder.. Can the part be replaced? Is this a common problem?
Make sure that it is a bear problem. Have you thought that it might be a coin stuck on the edge of the drum that rubs on the washers main housing structure? Good Luck
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Message ground container missing but is not
check the bins micro switch inside structure right side
Dec 20, 2010 | Schaerer Siena Espresso Machine
Dishwasher will not fill up with water and i already replaced the water valve
make sure the overfill switch is not stuck open. Under the bell like structure inside tub. Switch is behind kick plate on bottom front.
Oct 29, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
102 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
