Question about Intex Easy Set Pool 15x36
Fixing pin hole in intex pool - Intex Easy Set Pool 15x36
  • 990 Answers
You can get under water patch kits for this. They will have instructions with it. All you do is cut a patch to fit the aera then apply glue to the patch and fold in half with the glue side in. Then go down to the spot and press against the hola as you spread the patch back out. press the edges down and follow the directions as far as holding in place and how long to let it cure before you use the pool. Good luck.
Posted on May 28, 2010
5 Suggested Answers
  • 8404 Answers
SOURCE: I have 4 pin holes
Patch it from the inside. Get the special pool repair kit that allows under water patching. The kit I am talking about is superior to all others, expect to pay $12.00 . I use this kind of kit on my water bed though not from the inside.
Posted on Jun 05, 2011
Testimonial: "Thanks for the advice..I'll try to patching from inside-although I think it's a bit tricky to find the pin hole from inside while the pool is filled."
KMusselmann
  • 247 Answers
SOURCE: Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
Posted on Mar 23, 2009
  • 368 Answers
SOURCE: i have a 15 ft by 48 inch intex pool and i just
The most obvious thing besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Posted on Aug 22, 2009
  • 31 Answers
SOURCE: i just put up a
Well there are two solutions.
1st: fill the pool with water. (yes it will be leaking)
Get a small bowl and put some dish soap in it.
Next tape a sponge or a rag (or something you can apply the soap with) and scrub down the sides with the soap. Because the soap reacts with water and releases oxygen (or Co2, I'm not sure) when it does, it will bubble up and reveal where the leak is.
I think that's the most reliable way. Another way is only reliable if the leak is large. You can make everyone get out of the pool and listen very carefully at each side. If the leak is large enough you'll hear a sizzling.
I think that the first method would be more efficient, but the second sounds like it might do the job as well and would be easier.
To fix the hole, I believe that you'll have to fix it with a patch kit. The link below lists a few different options. It's essential to have a patch kit when you have a vinyl above ground pool because it's incredibly easy to get a hole in the side. I'd suggest buying a quality patch kit to insure that the patch lasts. You don't wanna waste the 120+ dollars on annoying recurring holes in the side.
http://www.google.com/search?rlz=1C1CHMY_enUS340US340&sourceid=chrome&ie=UTF-8&q=vinyl+pool+patch+kit#q=vinyl+pool+patch+kit&hl=en&rlz=1C1CHMY_enUS340US340&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=y_38TZi-N7LTiAKQ7dmIBQ&ved=0CEoQrQQ&bav=on.2,or.r_gc.r_pw.&fp=731789854f5bd5b4&biw=1280&bih=685
Posted on Jun 18, 2011
Goodday i have a intex pool notice water missing over a course of a week think it is a very small hole as big as a pin how can i find the hole please help
If the hole is in the bottom of the pool it will be extremely difficult to find. I assume you have looked around all the sides for wet spots already. How much water are you losing? Are you sure it is the pool leaking and not the pump or filter? Look everywhere!
Nov 05, 2013 | Intex Pool & Spa
My intex pool is leaking. We patched the holes we found but I think maybe I have a seam leak.
MY INTEX POOL RIM KEEPS GOING FLAT AND WE HAVE TO PUMP IT UP TWICE A DAY WHAT DO I DO ??? THERE ARE NO HOLES, WE HAVE TESTED IT
Jul 30, 2011 | Intex "" Metal Frame Pool Set (56998e)...
There a hole in our pool in we are trying to see what can we fix it with
Go to the pool supply place and get a underwater patch and repair kit. Read the instructions which will basically tell you to cut a patch from the supply roll, put on the glue and the fold it in half, get in the pool and apply the patch to the hole.
This what you are looking for?
Jul 27, 2011 | Intex Easy Set Pool 15x36
I have 4 pin holes on my Intex pool. I tried patching from the outside..but water is leaking thru the patch.. What am I doing wrong? Can they be fixed?
Jun 04, 2011 | Intex Easy Set Pool 15x36
Filter assembly Intex 15X48
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Jul 07, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Where does the hoses go and in what order do they go to join they to the intex 8ft pool
The two hoses are interchangeable...one to each hole, it doesn't matter which. Make sure you do this before the water level reaches the holes, but don't start the pump until after the water clears the intake hole.
Jun 13, 2010 | Intex Easy Set Pool 15x36
Kurt
Mar 23, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Intex Easy Set Pool 15x36 Logo
1,038 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
