Question about Polycom VSX 7000 Video Conference
Polycom Implementaion behind NAT on cisco Router
How to resolve the problem of Audio/Video in polycom behind NAT on cisco router. please help me in this scenario. If anybody have cisco configuration please share with me.
I have configured the static NAT onto the cisco router. Connection established successfully but it showed the Blank screen it means that Audio and video were not working properly.
SOURCE: POLYCOM SOUNDSTATION 2W
I thought well I wonder what holding down other buttons would do to get rid of this cursed PLEASE WAIT issue.
I tried * and # together and hey presto it worked.
I did however have to go in and turn IP mode off.
Posted on May 05, 2008
  • 3 Answers
SOURCE: Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
Posted on Jul 23, 2008
marsrover
  • 682 Answers
SOURCE: I have a Polycom soundstation
http://www.brennanit.com.au/UserGuides/User%20Guide%20-%20Polycom%20Soundstation2.pdf
Posted on Aug 06, 2008
SOURCE: Polycom wires
dont have yet
Posted on Nov 12, 2008
SOURCE: MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Posted on Dec 10, 2008
I'm trying to connect a polycom vsx 700 to this conference room. Same unit is able to connect to local scopia xt5000 with no trouble. If dialing 135.11.119.48 it times out without connecting to an
hello
This is not a dialing but trying to connect to the IP address setup in the system. Start editing the IP address giving the one that you would have already allocated to the device in the Router (i.e. 192.168.1.99) and then reboot it. It should connect then automatically.
Best regards
Dec 16, 2014 | Polycom VSX 7000 Video Conference
I have polycom 7000 with release version of 9.0.1 and second party having Polycom unit of 700 with release version now i am facing the poor video quality while connecting. Bandwidth at another end where...
Verify the uplink / download bandwidthon the broadband link.Broadband link do not have symmetrical upstream/downstream speeds. Perform test to verify.
Try non-peak hrs.
Check if latency is consistent.
Oct 14, 2010 | Polycom VSX 7000 Video Conference
Incoming audio fails from remote location
hi
as u mentioned, (firewall), when u do this the audio packets get blocked, u need to open the audio ports or best is to go for a dedicated bandwith only menat for the VC so there is no security issue & u can use the VC much comfortably
Dec 21, 2008 | Polycom VSX 7000 Video Conference
Polycom IP501 and SPA2102 Router
If you know how eo access your configuration control panel then assign a Static IP address or place that assigned address on the other side of the firewall (DMZ). Steve Medley
Nov 01, 2008 | Polycom Computers & Internet
Connecting a polycom
No, i don't think si. The polycom needs an ethernet connection to a router. You might get this working by putting the 3g card into a PC and enabling connection sharing, however even if you got it work itsd a bad solution in terms of:
- Cost
- Reliability
- Security.
ADSL would be better.
Jun 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Hope this helps..
May 06, 2008 | Polycom VSX 7000 Video Conference
Polycom NetEngine 3300R Port Capabilities
You'll have to set up Port Forwarding on the router, to port forward a port from the 'local' zone to the 'internet' zone. And i do hope your not viewing the administration pannel on the thing in German. (polycom is german, as is their website)
Nov 29, 2007 | Polycom NetEngine 3300R (2200-30128-001)...
Need advice on installing a Polycom 'Polyscan' video teleconferencing system
Some ideas based on your post/description:
It is very possible that the management/support software necessary to run your videoconferencing system resides or is installed in the PC based router that got burned. When you replaced the router with a NetGear, you simply provided an interconnection/distribution/forwarding/sharing of your Internet access to the different PCs of your firm but nothing to replace the server/management software for the Polyscan System. You have replaced only half of the PC based router - the router only, hence you have Internet acces but no video conferencing which is software managed which was installed in the PC half. Additionally, Polycom uses online Product Activation which might be necessary for your system to start working again.
Depending on the model of the Polyscan System that you have, it is also possible that you simply have to reconfigure the network settings of your Polyscan' System to match the new IP address of the Netgear (which might be very different from what the burned PC based router was using before). I understand that Polycom have several models (or series as they term it - PVX, TPX, RPX, VSX, HDX, and others). Would you pls post back with the series/model number that you are using?
Have you tried discussing your concern with Polycom Support? They might be in a better position to address this.
Hope this be of some help/idea. Pls post back with the Polycom system model that you are using.
Good luck and kind regards.
Nov 28, 2007 | Polycom (2200-30169-001) Router
Bad Video Quality in Sorenson VP-200 to PolyCom ViewStationEx Calls and vice-versa
If connected to a Cisco Switch, make sure the EX is not set to Auto for Speed or Duplex.
Oct 31, 2007 | Polycom Viewstation FX H.323
Polycom VSX 7000 Video Conference Logo
738 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
