Question about Microsoft Windows XP Professional
I have a problem in opening all programs on start button
  • John Anderson
    John Anderson May 28, 2010
    can you give me more details please on whats happening, or any errors you are recieving.. Thanks
    Master:
    Sergeant:
  • 383 Answers
They are like 5 dollars, buy a new one
Posted on May 28, 2010
How do I program a Digidoor 3 garage motor.
Limits must be programed. Power down and remove battery power ,press & hold button on motor pc board then apply power still holding button. The door should start running open and close. When it starts you can release button
Oct 31, 2014 | Building Materials
Tip
Set firefox as ur default browser
Windows 7 and Vista
  1. Click on the Windows logo to open the Start menu, then select Control Panel. The Control Panel window will open.
  2. Click on the link labeled Programs. The Programs panel will open.
  3. Click on the link labeled Set your default programs. The Set your default programs panel will open.
  4. In the Programs list on the left side of the window, click Firefox.
  5. In the right side of the window, click Set this program as default.
Windows XP
  1. Click the Start button, then click on the Control Panel icon to open the Windows Control Panel.
  2. Click the Add or Remove Programs icon to open the Add or Remove Programs applet.
  3. On the left side of the window, click the Set Program Access and Defaults icon.
  4. Click on the Custom radio button to expand the Custom category.
  5. Underneath Choose a default Web browser click the radio button next to Mozilla Firefox.
  6. Click OK at the bottom of the window.
if it helps u...pls vote
on Oct 03, 2010 | Computers & Internet
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Get fliptoast off my computer
If you are trying to uninstall the application Fliptoast used with/for Facebook then depending on what version of windows you're using (assuming you're using windows) go to: Start, Control Panel, Programs and select uninstall a program. Then find Fliptoast in the list and uninstall it from there.
If this does not remove it you can try a program call CCleaner and you can download it from here.
Once you have this program installed open it and go to Tools and Uninstall. Find Fliptoast in the list of applications, select it then choose Run Uninstaller.
Feb 28, 2011 | Computers & Internet
When I open the start buttom the computer does not show all the programes I had previously installed
Hello soiza4242, to find out if the "Programs" exist? do the following:
Click on the "Start button, and open the Control Panel."
Next select in the "Programs" category, [Uninstall a program] applet.
When the window open with the "listings of all the programs installed open; check to see if the ones you mentioned are there?"
{Alt / Right} click on a empty area to open the "Properties" shortcut.
Now, click on the [Customize...] button.
In the next 'window,' there will be a "Number of recent programs to display."
View the small box with #s in it, [ 10 > or< with up / down arrows].
To "Display 'more' Programs, click to {+add} arrow up!"
Click on the OK button when finished.
This will show more programs listed in the "Start Menu."
Now? If the "Programs aren't listed in the {Programs and Features}; then they will need to be "Reinstalled!"
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 15, 2011 | Microsoft Windows XP Professional for PC
Where is wireless button?
  • Hello heart2hea10, there are (4) four different ways to connect to the Internet. 1) To start, click on the "Start" button, paul7of9_20.jpg in the (right "start menu" pane), select the Control Panel 'shortcut' once the next window open; scroll to find, Network and Internet,paul7of9_21.jpg click on it to open. Next, select to open the "Internet Options." paul7of9_22.jpg To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button,paul7of9_23.jpg and follow all the instruction carefully. 2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process." 3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present" paul7of9_24.jpg Option is available?" select to open, and click on the Connectivity Doctor,paul7of9_25.jpg follow all instructions thereafter. (4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories, select to open: if you have the [Windows Mobility Center],paul7of9_26.jpg open the program; there will be a Wireless Network 'Turn-on and Off Switch"paul7of9_27.jpg Important "Always! Click Apply, Ok, and Restart the computer after making changes to the computer." "Did this solution help?" If so, "helpful Rating Feedback appreciated, thanks paul7of9."
Jan 30, 2011 | Toshiba Satellite L305-S5894 Notebook
Please describe how tu programing my keyPad for my craftsman 1/2 hp gararage opener.
I am assuming that you want to know how to program your garage opener with a remote control? In that case, open up the garage opener box (its mounted on the roof). You will see a colored button in there somewhere and above it is a small light. That button is called a "learn button." Push the button and hold a button on your remote that you want to program it with and the "learn" button should flash a few times. After it starts to flash, you can release the remote and it should be programed.
Nov 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
