Question about Dell Dimension 2400 PC Desktop
Monitor Issue my monitor will not come on when I connect to the computer and power up.
  • 596 Answers
If your pc is powers up but you get no video, your problem may be witht the monitor itself or the video cable pins (15 pin). If you pc does not power on, try removing the video card (if it is not part of your main board) and try to power up the pc. If the pc power up, replace the video card.
Good Luck
C2S
Posted on May 28, 2010
Testimonial: "I've tried these steps and found that it must be the video card."
My neovo 17 inch moniter not getting on
To help you troubleshoot the issue, please follow the instructions mentioned below,
-Make sure monitor power cords are correctly connected to the power switch and connectors.
-Check if monitor VGA cable is connected properly from the monitor to the computer connector.
-Make sure Power button is switched ON.
If issue persists, please try to replace the Power cord and VGA cable if feasible.
If issue persists, it is recommended to contact your monitor manufacturer for further assistance.
GuruAid.com
Apr 19, 2016 | Neovo Computers & Internet
Samsung monitor goes black
If the monitor works on the other computer than the first computer is not outputting a signal and the monitor is going to sleep. Alternately the monitor could have a power issue and it will just shut off after a few seconds. I've seen that happen.
Dec 13, 2012 | Samsung 2243SWX Monitor
Green p0wer light flashing on screen but no display
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly
vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Monitor settings are not correct
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your
Nov 27, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
No display
This issue can be caused by any of the below possibilities.
  1. Monitor is not on
  2. Computer is asleep
  3. Connections not connected properly.
  4. Monitor settings are not correct.
  5. No Post.
  6. Hardware issue.
Solution: The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
Nov 26, 2010 | ASUS P4S333 Motherboard
When i trun on my computer the monitor will not work. it says Check Signal Cable
  5. No Post.
  6. Hardware issue.
Solution:The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
If another monitor works on your computer it is safe to assume that your monitor is bad.
Nov 14, 2010 | HP Pavilion Slimline s3500f Desktop...
My monitor is plugged in and everything but it won't display
  5. No Post.
  6. Hardware issue.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
PLEASE ACCEPT IF YOU SATISFAID
Nov 14, 2010 | Samsung 932BW Monitor
DEAR SIR I HAVE ONE PHILIPS CRTMONITOR 107E61 MODEL PROBLEM IS POWERING ON BUT NODISPLY ALL SECONDARY Vg are ok pls help thanks and...
Cause:
  5. No Post.
  6. Hardware issue.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
Nov 14, 2010 | Philips 107E61 17" CRT Monitor
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
I facing no display, but led glows in red what i8s
1.Monitor is not on
3.Connections not connected properly.
3.Hardware issue.
Hardware Issue
PLEASE RATE THIS ANSWER IF SOLVED.
Feb 26, 2010 | Compaq EVO D5S SFF Refurbished Desktop...
Dell Dimension 2400 PC Desktop Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
