Question about Dell Inspiron 1000 Notebook
Does the dell inspiron 100 have a CMOS jumper? If so what does it look like or where can I find it?
  • Dell Master
  • 4,924 Answers
Just remove the keyboard and see that somewhere below have to be the bios battery ..if you remove it it will have the same effect ..some models have a switch for the cmos..but Inot all..jumpers are rare on laptops..if there are should be the only one..it is written clr .cmos ..near ..and it is placed under the keyboard..
Posted on May 28, 2010
5 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: Dell Inspiron 1525 CMOS chip
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&cc=us&dlc=en&product=441115&os=2093
Posted on Jun 13, 2009
  • 37 Answers
SOURCE: cmos battery on dell inspiron 4100 model PP01L
Reserve Battery Removing the Reserve Battery notice.gif NOTICE: The reserve battery provides power to the computer's RTC and NVRAM when the computer is turned off. Removing the battery causes the computer to lose the date and time information as well as all user-specified parameters in the BIOS. If possible, make a copy of this information before you remove the reserve battery. notice.gif NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries. notice.gif NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer. notice.gif NOTICE: Read "Preparing to Work Inside the Computer" before performing the following procedure.
  1. Remove the hard drive.
  2. Remove the keyboard.
  3. Disconnect the reserve battery cable from the system board connector.
  4. Pry the reserve battery free from the system board. The reserve battery is attached to the system board with a piece of adhesive tape.
  5. Remove any remnants of the adhesive tape from the system board.
reserve battery
speaker connector
Replacing the Reserve Battery
  1. Connect the reserve battery cable to the system board connector.
  2. Position the reserve battery above the speaker connector on the system board.
  3. Update the BIOS using a flash BIOS update program floppy disk or CD. For instructions on how to flash the BIOS, see "Flashing the BIOS."
this information was found on the following page which might be useful to you in the future.
http://support.dell.com/support/edocs/systems/ins4100/en/sm_en/remove.htm#1090379
Posted on Sep 30, 2009
  • 356 Answers
SOURCE: how to remove a cmos battery is a dell inspiron
The CMOS battery is located underneath the keyboard of your Dell i5100.
If you're up to it, then try these simple steps:
- Open the lid to a 180 degree angle and using a very small Flat Screwdriver, pry the hinge cover on the right side. There's a small notch where you can pry it out.
- Check if the keyboard is being held by 2 screws. To loosen them, remove the battery and unscrew them from inside the battery bay.
- Carefully lift the keyboard in an angled position and check the ribbon or contact tape that connects the keyboard to the motherboard. Flip the keyboard towards you and see if you can reach the CMOS battery (usually covered by a blue plastic shield or protective cover. There's a pair of wire coming from it and the end is a small connector. You may remove the connector attached to the motherboard carefully to get the CMOS battery.
Posted on Jun 13, 2010
SOURCE: cmos jumper or switch dell e1505
www.mastermindit.biz has $20 bios master passwords, via paypal so your transaction is secure and free from shadyness! I got one off of him for a Dell e1505 that Dell would NOT let me xfer ownership of, so I couldn't get the PW from them period! He literally saved my arse!
Posted on Oct 06, 2010
Dude, Can you send me a Bootable ISO CD of Dell Asset/Service Tag BIOS Reset Tool........Please
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd
Dell
The official method is to contact Dell Technical Support. Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Latitude. If the current user is not the original Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
  • Dell Inspiron 5100: eeprom 93lc46, password in scan code at 0x310
  • Dell Inspiron 7500: eeprom 24c164
  • Dell Inspiron 8100: eeprom 24c02
  • Dell Latitude C600: eeprom 24c02, password in scan code at 0x00, 0x10 and 0x90
  • Dell Latitude C610: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80 and 0x90
  • Dell Latitude C640: eeprom 24c04, password in scan code at 0x100 and 0x180
  • Dell Latitude CPI: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80
  • Dell D600: eeprom 24c04, password in scan code at 0x110
  • Dell Optiplex: Remove the PSWD jumper
  • For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
    • Locate the 3-pin CMOS password reset jumper on the system board.
    • Remove the jumper plug from pins 1 and 2.
    • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
    • Replace the jumper plug on pins 1 and 2.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper: In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
Feb 05, 2013 | Computers & Internet
Need to know where bios jumpers are on a dell inspiron mini 1012
I don't think a laptop has them. Removing the CMOS battery for a few hours had no effect?
Dec 28, 2012 | Dell Inspiron Mini 1012 Netbook...
Wheres the cmos jumper in dell inspiron e1405?
All you need to do is remove the cmos battery and main battery, short across the positive and negitive terminals where the cmos battery was, that will reset to factory default, however if you are hoping to remove a bios password this will not work no matter how long it is without power. The information is stored on a epprom chip.
Mar 15, 2012 | Dell Inspiron E1405 Notebook
Unlock dell inspiron 1521 unknown bios pswd
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Feb 12, 2010 | Dell Inspiron 1521-JB Notebook
How do i reset bios password on a used dell 710m inspiron?
For you to reset the bios all you need to do is to take it out, but before you do that you'll need to power off your laptop.
Regards
Oct 13, 2009 | Dell Inspiron 710m Notebook
Bios backdoor password needed.locked out of bios. can you help?
For those with Fujitsu Lifebook specially with PhoenixBIOS never remove your CMOS battery no matter what happened.Or else you cannot used your laptop forever....You will surprised 100% with these message
Warning
020F: PASSWORD LOCKED: Fixed Disk 0
F1 resume F2 Setup
So beware...
Jun 13, 2009 | Dell Inspiron 1501 Notebook
I have a dell inspiron e1505. i have taken out the mother board but caint find the jumper or cmos chip can you tell me where it is and what it looks like.
There may not be a jumper. Most laptops have the CMOS battery soldered to the motherboard and the only way to reset it is through the bios screen.
Jun 03, 2009 | Dell Inspiron E1505 Notebook
How do I reset my lost bios password for Dell Precision M70
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Need jumper dell 1520
There is no jumper. Were you trying to reset the bios? Give me some details and I can help.
May 11, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Dell Inspiron 1000 Notebook Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
