Question about Vtech Lands Phones
I get no dial tone just static on the line-i dont know if it is the channel or how to set up right channel-everything else works it rings and shows caller id too.
  • r5e1a3 Jun 02, 2010
    yes thats what i needed ! thanks
  • 2,069 Answers
Could you please indicate what phone brand it is. someone will surely assist you better from there. but generically, check the phone line cord, make sure it is the right one and inserted properly and in the right sockets.
Regards
Posted on May 28, 2010
  • r5e1a3 May 28, 2010
    it is a v tech phoe cordless model # t2326 it is not the phone line or the jack because my other phone works on that jack with no problem i just don't have the book for the phone to find out how to program the right channel in there
  • Muzahura Frank May 29, 2010
    please download its manual from here. hope that helps you and please don't forget to rate my help.
    Regards
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
Cannot get the pulse tone off the line and that prevents from voicemail access and call forwarding HELP!
In guessing that since your lines have defaulted to pulse dialing that you have an older Nortel system such as an 8x24 or a 6x16 system. That being said you'll need to program touch tone dialing on each line.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
4 top line/feature keys are now used for programming
Press the show key (top right arrow)
the display will say1. trunk/line data
Press the show key (top right arrow) .
the display will say line 001.
the display trunk data
press the show key (top right arrow) Press the next key 7 times(bottom right arrow) .
The display should say Dial mode: pulse.
Press the Change soft key (below the display).
the display should now say tone. press the heading key (top left arrow) to get back to "trunk/line data" repeat the steps for the remainder of your active lines
press Rls when finished
Nov 04, 2010 | NorStar M7208 Corded Phone
Hi there ... We have 4 lines in the office but on one of our M2000 series Meridian phones only the first 2 line buttons receive a dial tone ... How do add lines 3 and 4 to the next 2 buttons?
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program the new lines on.
The display should sat LINE ACCESS
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 003:unaaign.
press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 004: unassign
press the chng key til the screen says appear&ring
press the Rls key when finished
Jul 03, 2010 | NorStar Meridian M7310 Phone
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
Phone line won't hang up
I would check the DSL filters. Your phone should not interfere with the DSL. Make sure there is a filter on any line going into your phones. If there is a filter replace it and see if that works. Also, check other equipment on the line, fax, computer, credit card machine. They will need filters from the DSL too. Remove these other devices and check the line for the problem then add them back one at a time.
Aug 01, 2009 | AT&T 964 Corded Phone
Have dial tone but can't dial out
I just spoke to RCA and they said to unplug power and phone line and take out batteries, wait 5 minutes and plug everything back in, mine now works.
Apr 23, 2009 | RCA ViSYS 2-Line Speakerphone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Panasonic Phone - no dial tone
The Expert was not able to help me. He read the same manual I did - I still can't get my phone off phonebook or get a dial tone. At times my intercom phone will say, "line in use". J.
May 20, 2008 | Lands Phones
Lands Phones Logo
26 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
