Question about Virtual Reality Sound VR3 CD Player w/ USB and Scan Disk Inputs
Car radio installtion
I need help with installing my radio in my car i am not getting any power and i do not have the money to pay for someone to put it in
I just installed this radio today. I found that using a wiring harness for my car really simplified it. You can usually find one at an auto parts store or sometimes WalMart. Mine cost me $10. It has a list of what wire is for what, so you just match it up with the same specifications on your stereo wires (there is a tag on each wire that tells what it is for). Hope this helps!
Posted on Apr 26, 2008
SOURCE:
I need a radio code for my car and do not have money to pay for it, can you help me??
Is it a 4 digit code or 5 digit code as you will have between 10000 and 99999 possible codes to input
So get imputing or find the money is the only two options
Mar 28, 2015 | Cars & Trucks
2002 toyota camry xle v6. I had the air filter changed and the battery changed and now my car will start but wont stay running unless I am pressing the gas pedal. My car was running perfect before I let...
You know the answer
The shop put the problem in there
Retrace their work
Loose Air Filter box cover & unmetered air
entering the ducting
Now the MAF Sensor can't get a correct read on the
incoming air flow
No reason to have to pay someone to install an air filter
or even a battery
Ask a neighbor for help next time & save money & know
you did the job correctly
Jan 21, 2013 | 2002 Toyota Camry
I just bought a 2004 chevy impala for my son but the radio is locked. How do i unlock it and will i have to pay a lot of money?
If your car came with an owners manual the instructions should be in there to unlock your radio. However if someone reprogrammed your radio with a code other then the factory code you may need to take your car into the dealer to have it reset. This will run you around $60. I hope this helps you out, and if you have any other questions please feel free to ask.
Sep 17, 2011 | 2004 Chevrolet Impala
I am attempting to intergrate my aftermarket stereo with my 2004 buick century (without onstar) and I do not want to spend the money on an adapter. I have the wiring diagram to let me know which wire are...
It sounds as if you are trying to hardwire the aftermarket stereo into the factory wiring which is a bad idea if you are going to cut the plug off the factory harness. An aftermarket harness does not cost that much money, especially in comparison to your car. If you insist on damaging the factory wiring, and all but ensuring you'll have to leave that radio in the car when you try to sell it, nobody will stop you. The nearly universal color codes for aftermarket radio wires is as follows. Front left +/- White, White/Black. Front Right +/- Grey, Grey/Black, Rear left +/- Green, Green/Black, Rear Right +/- Purple, Purple/Black. Yellow is your 12 volt constant (battery), Red is ignition, blue is power antenna (if your car has a power antenna), blue with white strip is amp turn on (if you are going to use an external amp). I wouldn't suggest using illumination and dimmer wires (orange/white and orange) because they have been known to cause damage to people's instrument clusters and other interior lighting, but proceed at your own risk there. Again, it would really be better to just spend a few dollars and get an aftermarket harness--this is what they're designed for, so that you don't cut up your cars factory harness (which are very expensive if they ever need to be replaced, and I imagine you'd want to put the factory radio back in once you get rid of the car, because nobody will pay extra for your aftermarket radio, and most people buying a used car want everything factory so it feels like a new car to them, instead of a reminder that someone else had the car before. Just think about it, but aside from that, I hope the information will be useful to you.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 07, 2017 | Panasonic CQ-C3403U CD Player
I need code for bmw reverse rds info: bp3836r1038325 7 643 836 340 r1038325 can someone please help me?pleaseeeeeeee
sometimes you can look in the glove box and find the code for the radio but you have to remove the radio and get model number and serial number from the back of radio .
then goto radiocodes.com only thing bad about this site is the faster you want the code the more money you pay .
any more questions email me at [email protected]
Oct 16, 2010 | Car Audio & Video
I have a 2001 corvette, and the cd player, when you put a cd in to play I get an err and kicks the cd back out , but the radio plays fine
you need to take it back to the dealer to program the cd or clean the laser if its still has warrenty that way you dont pay alot of money for the job if they cant program or clean replace the sterio if need a estimat call 520-882-8979
Jun 10, 2010 | Corvette Chevy Malibu 90-04 Car Radio...
Trying to install a jvc radio in my ford truck but I dont know what wires to conect to the radio so I need to know what color of wire are for the speakers, left and right and the power andground
WOW thank you for the vehicle information that help a lot
maybe it will be better if you pay someone that know what they are doing, for anybody else go here
full instructions for most vehicles
http://www.installdr.com/
Mar 31, 2010 | Car Audio & Video
What kind of battery for 1999 Chrysler 300
Not sure of why you are asking the question, so I'll give you my two cents:
1. Most any place selling you a battery can tell you what size battery fits in your car. Sometimes, more than one size will fit.
2. In general, always put the biggest series of a battery that will fit. For the same manufacturer, same style/model of battery, bigger is better. The more lead, the more acid available, the stronger the battery, the longer lasting power to start your car.
3. How long are you keeping the car? If you plan to get rid of it in a year, then don't spend money on a 72 month battery. Get a cheap one, almost any battery will handle a year as long as the alternator & charging system is working right.
4. Can you change it yourself, or will you have to pay someone? If you can do it yourself, best deals are usually had at an auto parts store rather than a retail or auto repair shop. Walmart may have a better price than any, but less likely to find someone who can help you determine what size battery for your car.
5. If you have to pay someone to install, consider whether you travel a lot. If you may need to get the battery replaced while you are on the road, a large chain is more likely to be there to help you. (This holds true for a do-it-yourself battery replacement as well as if you get them to replace it. Autozone is pretty much nationwide I think, Joe's Bar, Grill & autoparts may not be. (((SMILE))))
6. Finally, most autoparts stores will test your charging system for free. I think a lot of mechanics may do the same IF you buy a battery from them. It's a good idea to have this done to make sure the problem is just a battery and not a faulty charging system.
Not sure if that helps, but hope somewhere in there I answered your question.
Sep 23, 2009 | 1999 Chrysler 300M
Car Radio bench test procedure and special equipment???
Hi and welcome to FixYa,
Could you post back the exact model of the Alpine radio/head unit pls? It would also help if you know what was originally installed in your vehicle, if there is an external amp and how many speakers are currently installed. Some high end vehicles also uses the car radios/stereos for alphanumeric displays, might this also be in your car's model?
Would appreciate postback. Good luck and thank you for using FixYa.
Feb 13, 2009 | Alpine Car Audio & Video
Help me fix my booboo
take a test light put the ignition kee on chek witch wire has battery power assesorry power and ground normally cd player have wire black for ground yellow fore assesorry and red for power the other wire in the car make sure that they is no power to it the rest is speaker wire one at the time our gonna work be carefull go easy and if you not sure go see a radio shop better pay a bit of money then frying the radio cheers
Jan 08, 2008 | Pioneer DEH-P2900MP CD Receiver...
Car Audio & Video Logo
88 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Bill Boyd
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
