Question about LG enV3 VX9200 Cell Phone
My env3 got wet how do I take it apart to dry it out? I laid it face down on my night stand beside a cup of ice water. The ice melted and ran out on the night stand and my phone has water in the key board and the front screen. Can it be saved?
  • 973 Answers
I wouldn't take it apart, I would just take the battery and battery cover off and use a hair dryer on medium heat and blow it inside and on the outside, don't let it get hot though, just enough to dry it.
Posted on May 28, 2010
I have a Whirlpool refrig./freezer. I have no problem with the ice dropping in the bucket,but when I try to dispense it under the chute,it wil not dispense. The water works fine. This is a side side ...
Sometimes the ice will collect, melt, and freeze into a giant headache. If you have the one where you can get ice out of the holding bin inside the freezer, see if the ice bin will come apart from the rest of the dispenser. If it doesn't come easily, get as much ice out of the bin, get a wet vac ready and pour warm water on the ice. It will run through the dispenser. Once things come apart easily, you can take it over to sink and get rid of the ice blockage with warm water, let it dry, reinstall, and check to see if it works. Hope this helps.
Nov 03, 2013 | Whirlpool 21.8 cu. ft. Side-By-Side...
Freezer door not sealing at bottom right side
if you removed the inner section of the door for the drying process then it is possible that the door has warped and you have locked it in that shape on installation of the inner section
loosen off the screws and twist the door so that it touches all the way around , then retension the screws
make adjustments at the hinges after that
Jul 09, 2017 | Amana SXD524VW Side by Side Refrigerator
How do I make my EnV3 stop vibrating?
Take out the battery and put the phone in some rice. It should help completely dry your phone out.
Dec 04, 2011 | LG enV3 VX9200 Cell Phone
Whirlpool refrig - i'm finding water under the vegetable bins and on the top shelf in the mornings. Freezer has no problem and is defrosting fine. I can't figure out where the water is coming from. No...
there is a drain in the freezer so when the fridge defrosts the water drains down to the pan in the bottom of fridge,your drain is blocked,you need to take off the inside freezer back wall,melt out the ice with a hair dryer and then unblock the drain,i use a steamer to do this,they cost around 50 bucks,the drain line is plastic so you don't want to go sticking anything down the line that can damage it,slime builds up in the line or food particles go down the drain and then ice builds up in the line,the steamer cuts through this and sanitizes the line,if the drain goes strait you can install a heater probe,it's just a piece of metal that you rap around the heater and stick the other end down the drain hole so it won't freeze up again,when you think the line is clear,pour hot water down the drain to make sure it's clear,be careful when melting out the ice with hair dryer,to much heat can damage the styrofoam,make sure the air vents are melted out,they are the holes in the styrofoam,you might have to melt it out from inside the refridgerator section heating the area up on the ceiling,also make sure the control is shut off to the freezer,you don't want the fan to be blowing,good luck
Jan 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
My Jenn-air side-by-side refrigerator is leaking water from the freezer side (left as you stand facing it. When I open the freezer door, the ice is half an inch thick on the bottom of the freezer and has...
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 26, 2009 | Refrigerators
GE Refrigerator Stoped making ice
the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Tub still wet/ not drying
YOU NEED RINSE AID ! ! Make sure your selection option is HEATED DRY.Please rate this !
Jun 06, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
LG enV3 VX9200 Cell Phone Logo
936 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
