Question about LaSpaziale S1 Rossini Espresso Machine
When I turn on my S1 Rossini, the low water light comes on when the water receptacle is actually full. When it first started doing this, I could take the water receptacle out & shove it in hard, or keep sustained pressure against it, & it would shut off. Over time this has become ineffective, until finally this morning after trying 15 min for that stupid light to turn off...it beat me. Do you know what's wrong, & how can I fix it?
How to work a pressure washer?
hook up the water hose before turning electric on have the hose supplying water to it low pressure these units cant take full pressure like over 60psi, thenturn the dial to where you want andconnect power use 3 way adapter prong outdoor style extension with a good outside coded plug receptacle of course
Apr 04, 2016 | Karcher K 2.56 M 1,500 PSI 1.3 GPM...
Oil light comes on when I turn on the key and goes off as soon as I start up, oil is full on dipstick
It's supposed to do that. The light comes on when oil pressure in the engine is low as it is when not running, this actually shows it's working as it should. It's when it comes on while the engine is running you need to worry, but as you know how to check the oil level on the dipstick you should be OK. You should check oil regularly if you care about your engine, once a week is recommeded. Do it when the engine is cold.
Jan 02, 2016 | Goes Motorcycles
Postal code for 826 Rossini Blvd.Windsor,ON.
826 Rossini Blvd Windsor, ON N8Y 2Z3
Feb 27, 2015 | Computers & Internet
My low oil pressure and low engine oil light are constantly coming on in my van but the oil is full?
If you have two different warning lights, it could be a wiring problem.
The low oil pressure warning could come on even if the engine is full of oil. If that is the only light coming on, it could be the sending unit or you could actually have low oil pressure.
Feb 25, 2013 | 2000 Chevrolet Venture
Light for water is coming on but coolent is full
what color is the light.....as there are 2 lights, one is red, and comes on if water is low or suspect...and then there is the blue light that comes on when you start the car and goes off as the engine heats up.........
Feb 21, 2011 | Saturn SL2 Cars & Trucks
1999 Olds Alero. Low coolant light comes on and stays on even though its full. Starts running hot to the 3/4 mark. When the heater is turned on it cools off. Could this be the thermostat or the water pump.
TAKE RADIATOR CAP OFF WITH ENGINE COLD AND CHECK WATER ..MAKE SURE RADIATOR NOT BLOCKED,,PLASTIC BAG ETC. THIS SOUNDS LIKE LOW WATER OR RADIATOR ..STOPPED UP INSIDE ..IF YOU HAVE GOOD HEAT IT'S FULL OF WATER. REPLACE T STAT B4 RADIATOR..IT'S CHEAPER. ALSO CHECK FOR RADIATOR COOLING FAN OPPERATION..I,M RULING OUT THE WATER PUMP.
Mar 20, 2010 | 1999 Oldsmobile Alero
Everstar MPK10CR-1 water not draining into receptacle
there is probably alot more humidity in your area this year than in the past. these units will the the condenstion water to help cool themselves by splashing it onto the condensing coil. the unit is apparently making more condesation then it can use os the extra goes into the collection pan. the FIX is hook up the drain hose.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Does anyone have a user's guide for the S1 Rossini?
I have a user guide for the S1 Vivaldi which is usable (except for instructions dealing with dual boiler) for the Rossini.
Feb 06, 2009 | LaSpaziale S1 Rossini Espresso Machine
Difficulty changing a low beam lamp on my 2002 mercedes c320
FIRST DISCONNECT THE LIGHT FROM THE POWER ON THE LAMP YOU ARE TRYING TO REPLACE. It is a plug type that will pull as the sides are pushed. NEXT, The light will have a WIRED brace holding it on. Look closely. Pushed the WIRED brace at an angle and wiggle it. After it comes off and hangs there like a latch, turn the receptacle of the actual light counter clockwise and it will come out. Replace bulb and do the same thing opposite of what I explained.
Jan 08, 2009 | 2002 Mercedes-Benz C-Class
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
LaSpaziale S1 Rossini Espresso Machine Logo
83 people viewed this question
Top LaSpaziale Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a LaSpaziale Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
