Question about Kenmore Single Room Air Conditioner
What is the power draw (in watts or amps) of the Kenmore 5300BTU room air conditioner? The unit is being powered off the grid by an inverter, and I think the user chose too light weight an inverter for the load.
  • Kenmore Master
  • 8,220 Answers
5.8 amps. see page 9 (5300 btu is considered a 6000 BTU, 4800 is considered 5000 btu, sorta like a 2x4 ain't really a 2x4 LOL)
You cannot run an ac on an inverter, not enough juice to get it started.
Posted on May 28, 2010
Dometic brisk 2 AC can it be operated on a 24 volt inverter.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
Oct 29, 2015 | Dometic Rooftop RV Air Conditioner
Not cooling anywhere near what it claims.
Try to turn OFF the Music Mode Only.
Turning on Music Only Mode will disable voice and data calls..
Regards
Sep 07, 2008 | Soleus LX-140 Portable Air Conditioner
A NEED A POWER CORD FOR THIS UNIT
Electrical Characteristics (60 Hertz)
Volts Rated: 115
Cooling Amps: 12.0
Cooling Watts: 1,343
Heating Amps: N/A
Heating Watts: N/A
Circuit Rating - Breaker or TD Fuse: 125V - 15A
Plug Face(NEMA#): 5-15P
This unit is 115vac and 15amps draw.
Find a heavy cord. ACE or Home Depoet
May 01, 2014 | Friedrich QuietMaster KS15L10...
What's your problem?how many amps on a 1/2 horse sump pump
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Apr 28, 2012 | Black & Decker Husky 750w Power Inverter
I need an inverter for my 1 hp air condition. how many watts do i need especially at start-up? modified or pure sine wave. Thank you.
The most important spec that you will need is the LRA rating. What this stands for is locked rotor amps. The LRA rating is what the AC unit will draw from the inverter while the compressor starts up. This is a very important spec when sizing an inverter for use with an AC unit. After you get this spec you will multiply it by the voltage and this will be the startup wattage needed by the inverter.
For example if your LRA is 60.6 amps if you multiply this by 115 you will get roughly 7000 watts at start-up.
The next thing to take into consideration for a AC unit is battery bank size. Your next step in setting up a system for use with an AC unit is finding a sufficient recharge source for the batteries. You will want to have a minimum of a 150 amp alternator to recharge a system with a small AC. I do not know whether you will be able o accommodate them.
Why don't you go for solar power as standby OR a small generator????????
Aug 05, 2011 | Inverter Heating & Cooling
Can a 3000 wat inverter run this unit
Maybe, the way to figure that would be the 20 amp draw of the unit times the 120 volts that the unit runs on which gives you a wattage of like 2400 watts...that is really very close to the max output of the inverter and it may cause it to over heat...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Coleman Mach III Air Conditioner
How many watts does an ARP-3012 draw?
Assuming you are in the United States....
This unit should work fine on a 15 amp circuit assuming there aren't several other loads on the same circuit.
You didn't say what the BTU was for you unit, but there are about 3.41 BTU's per watt. Multiply the btu rating of your unit by 3.41 and then divide by 115 or 120 (your house voltage in the U.S., use 220 for Europe) and that number is the amps.
Apr 07, 2009 | Royal Sovereign ARP-3012 Air Conditioner
Aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Duotherm 1350 Btu's air conditioner breaker problems
Are you using a long lightweight extension cord? This unit alone draws almost 1000 watts. On a 20 amp circuit this doesn't leave a lot of room for other appliances and lights. If this is a brand new unit and the extension cord is the right size the air conditioner should still be under warranty.
Jul 03, 2008 | Dometic GEN3107206 Air Conditioner
Maytag M3X05F2A
Your unit is 515 Watts using 115V (line to ground.)
Maytag M3X05F2A
Specifications:
• Volts 115
• EER 9.7
• Amps 5.0
• Watts 515
• Plug cap. amps 125/15
• Pints per hour 1.4
• Room air (CFM) 160
Room Size:
• 10' x 15'
• 150 sq. ft.
If you plan on using it in the Philippines the electrical power supply is 220V line to ground. You can use an Auto Voltage Regulator (AVR) which has an internal winding with a servo that moves a carbon brush across the winding. I would recommend that you use at least a 1500 Watt AVR as the longer you use it the hotter it will get. Hopefully you can find an AVR with 3 pronged outlets. I currently use 3 ea. SIEG models SVC-888-1000 VA (600 Watts) for most electronics and 1 SVC-888-1500VA on a small 11 Cu Ft. freezer. The Freezer is 626W but uses almost 700W during the defrost cycle. The AVR failed after 3 years due to overheating. (STINK!) I also have a 4th SEIG model SVC-888-3000VA on my 21 Cu Ft 115V Refrigerator. There are other AVR manufacturers here and the cost vary greatly by manufacturer. (P3300 - P6500 depending on model) I have has all of my AVRs in countinous service for almost 6 years.
Jan 13, 2008 | Maytag M6Q10F2A Air Conditioner
Kenmore Single Room Air Conditioner Logo
247 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
