Question about Honeywell Programmable Thermostat Heater
I have just installed a Honeywell programmable thermostat RTH2310B1002 replacing my old Honeywell that contained mercury. I hooked all the wires to the corresponding colors and letters and the system runs the fan but no cold air comes out and temperature on thermostat reads 80 degrees all the time. I don't think the air conditioner is bad it only took 15 minutes to install the new thermostat and the a/c was working right before i replaced it no more than 20-30 minutes before. how do i resolve the issue?
  • 420 Answers
Make sure the "RH" wire also connects to "RC"
("Red for Heating and Red for Cooling)
Posted on May 28, 2010
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
I am replacing a 10 year old Honeywell Thermostat with a mercury switch with a new programable digital Honeywell OS#RTH7500D1007 MD 0638. There a 4 wires coming out of the wall and are installed on the old...
You are on the right track, you can hook the same 4 wires to the new thermostat without the jumper you had on the old thermostat. The jumper wire that is on the new thermostat can stay with no problems. Just connect the wires to the same terminals on the new one and your good to go!
May 10, 2011 | Honeywell Electronic Programmable...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
Where to hook up wires?
First, take the old thermostat off the wall.
there should be different colored wires coming out of the wall still connected to the old thermo.
on the new thermo, there might be a wire color chart in the instructions or on the inside of the new thermo.
You should be able to line up the colors and install them that way. let me know if you have any other problems
Jan 12, 2009 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Heat pump thermostat replacement
It sounds like your reversing valve energizes the opposite from how you wired it at the thermostat. Check the instructions.
Oct 28, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
909 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
