Question about Siemens SpeedStream Modem (4100) (SS4100)
How do i add udp ports 5198- 5199 - Siemens SpeedStream Modem (4100) (SS4100)
  • 506 Answers
From Control Panel click on the firewall Icon, Advanced settings, Connection and security rules, New rule, Custom, Protocol and Ports. In Port Type choice UDP, in Endpoint 1 port choose specific Port, in the text box bellow enter your start Port. do the same for Endpoint 2 Port. Complete the setup by clicking next
Posted on May 28, 2010
XBOX ONE CANNOT CONNECT TO THE INTERNET THROUGH WIRELESS ROUTER
my first guess would be you need to open ports in your firewall.
  • port 88 (udp)
  • port 3074 (udp and tcp)
  • port 53 (udp and tcp)
  • port 80 (tcp)
  • port 500 (udp)
  • port 3544 (udp)
  • port 4500 (udp)
Jan 21, 2015 | Computers & Internet
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My nat is strict
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Regards
TOM
Jan 26, 2011 | Computers & Internet
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
How do i set my tcp port range and udp
Following steps will help you out:-
1)Open the router gui with 192.168.1.1 or http://routerlogin.net by typing it in the address bar for the user name as admin and password as the word password only.
2)On the Netgear smart wizard .left hand side you will find a small blue/purple column with different categories , look for the one that says advanced and click on port forwarding/port triggering and select port forwarding from there and click on Add custom service from the bottom .
3)A new screen will appear which will have the following options:-
Service name:-
Service type:-tcp , udp , tcp/udp
Starting port:-
Ending Port:-
Server Ip Address:-(enter the value in range) and apply the setting's.
Nov 16, 2009 | NetGear RangeMax WPN824 Router
It works fine untail I want to play Asherons Call a MS game, firewall has locked me out, how do I shut off the firewall. tyvm Ken
What you want to do is "open ports" in your firewall. This is simple if you have admin access to your router. Find the section for "port forwarding" and add ports that your game require. Typically, there is a TCP port and a UDP port. The UDP is for broadcasting type messages to/from your fellow gamers. The TCP port is usually for the game server. Check with your game instructions -- or you can probably get the answer with a google search string of "game ports Asherons Call" and I would bet it will give you exactly the settings for your router.
Here ya go (I did the google search). It appears that it only requres the UDP port. I would open all of these unless you find out more detail that you can close some ports (never leave a port open that you don't know or don't need -- it is a hackers door to your computer).
9000 UDP Asheron's Call game
9010 UDP Asheron's Call game 9011 UDP Asheron's Call game 9012 UDP Asheron's Call game 9013 UDP Asheron's Call game
Good luck.
Apr 27, 2009 | Computers & Internet
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
What is portforwarding
You need to login to your router and go to firewall or virtual servers.  In there you can setup port forwarding.  The goal is to forward external (internet) traffic to a specific internal machine (your PS3).  You do this on a per TCP/UDP port basis and must specify the appropriate external TCP and/or UDP port and internal TCP and/or UDP port.  Sounds harder than it is.
Or you can setup your PS3 in your router's DMZ (Demiliterized Zone).  This sets up the router to forward ALL internet sourced traffic to a specific machine (your PS3).  This is the easier way to do it so you don't have to worry about specific TCP/UDP port numbers.
Jan 24, 2009 | Linksys Wireless-G WRT54GX Router...
Optimizing WGR614(v1) for xbox live
the normal port that requires opening in your router for xbox is TCP3074, you should just type the number in as if there are no options, although there should be, it may know that 3074 is a TCP port.
Sep 28, 2007 | NetGear WGR614 Wireless Router
Siemens SpeedStream Modem (4100) (SS4100) Logo
264 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
