Question about KitchenAid KEYS750LQ Electric Dryer
Dryer wont heat. please help - KitchenAid KEYS750LQ Electric Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 28, 2010
My gas dryer wont heat. kenmore 97274100
wer
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 27, 2010 | Dryers
My dryer doesn't have heat anymore, and i already got the new heater but the new heater still doesn't work. Please help.
have you taken the vent hose off and felt to see if it is blowing hot air? Here is a website that has possible solutions to no heat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 29, 2010 | Kenmore Dryers
My dryer wont heat up.suddenly stopped heating...rotates just fine.. Kenmore 400 seriies gas dryer..please help
Make sure to check all the thermal fuses in the dryer.
if one of the has not got any continuity then replace it.
there is also a chance that the ignitor has gone bad and is not allowing the gas valve to open.
Jul 03, 2010 | Dryers
Wont heat
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 06, 2010 | LG DLE7177 Dryer
Dryer won't heat?
Make sure your electrical connections are correct.
Check the voltage to the dryer element and make sure you are getting 220 volts.
Otherwise I am at a loss also...good luck
I hope this helps
Oct 01, 2009 | Whirlpool Dryers
Kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 28, 2009 | Dryers
Wont heat up
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 17, 2009 | Frigidaire GLER642A Electric Dryer
Dryer wont stop Timer wont work either Cycle
058aeba.jpgReplace the heating element if it is bad. if it is not then replace the high limits mounted on it at top and bottom
Sep 27, 2008 | Roper RES7646KQ Electric Dryer
I replaced the belt on dryer, still wont start
hiya
have you checked the small plastic ****** on the door? sometimes these bend due to the heat and dont press the microswitch to allow the dryer to start.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Dryers
KitchenAid KEYS750LQ Electric Dryer Logo
32 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
