Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a new lamp and it works for about 1min. the it cuts off over and over again. magnavox tech support says i need to reset the timer. how do i do this, and is this really the problem?
  • steve moton May 28, 2010
    thank you for your solution i hope it works as i need further assistance.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From the description you have provided it seems that the ballast has gone bad as it is the power source for the lamp and required to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 28, 2010
    how do i replace the ballast, how much does this usually cost, and can i obtain it at a parts store?
  • Rylee Smith
    Rylee Smith May 28, 2010
    Thanks for accepting the solution, Please click on this link for parts.
I changed the lamp in my sp7210 the new lamp is working fine but.
just to be sure you have the correct timer reset procedure: power the projector up, press and hold down the 2 brightness buttons for at least 10 seconds. if that doesn't work, you'll need to upgrade the firmware. go to the infocus website.
Jan 18, 2010 | InFocus ScreenPlay 7210 Multimedia...
My tv turns its self off after about 30 seconds and all the red lights come on, any ideas?
This may be an issue with the lamp needing replacement or a fan not working or some other issue with the power up sequence not getting the right codes to power on. You can try a new lamp and reset the timer. but most likely I would have a repair service look at it.
Jan 16, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Mitsubishi HC 900 DLP Projection Lamp Shutdown.
Honestly I would try entering the 'Lamp timer reset' code again. Or the button sequence given to reset the lamp timer.
An issue that may be happening is that something may have happened to the lamp ballast power supply also.
Just a thought.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Purchased a new lamp, tv worked fine. about 10 days later it stopped working and the lamp light is flashing again.
Did you reset the lamp timer? If you dont reset the timer the TV thinks the old lamp is still in use.
Nov 26, 2009 | Cars & Trucks
Lamp light just blinks yellow after lamp replacement, tv does not turn on
I will recommend to take the lamp out and slide in again, it might be that your TV havent detect that there is a new lamp. By doing this you will reset the lamp timer. If dont work search in your manual how to reset the lamp timer.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Epson 7300
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Apr 17, 2008 | Office Equipment & Supplies
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Lamb will not reset
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
