Question about Dishwashers
Water remains in dishwasher after cycle is done !
  • 159 Answers
The pump out may be blocked.A lot of people dont clean out the filters inside the dishwasher causing blockage,also maybe piece of debri could be jamming the pump impellor,or hose connection under sink is blocked.
Posted on May 28, 2010
  • chrizzoclark May 28, 2010
    There is a blockage somewhere in the pump out system.or the pump itself is jambed with debris,or the pump is just dead,also check the drain hose where it connects to the S bend under the sink for blockage.
Should any water remain under the glass trap after cycle has finished on a frigidaire dishwasher?
Good Afternoon Friend,
I understand that you want to know if any water should remain under the glass trap, on your Frigidaire dishwasher, after the cycle has finished. Per the owner's manual, "it is normal to see a small amount of water under the filter at the end of a cycle." Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Dishwashers
Danby dishwasher not washing
see this possible causes: 1) water heating cycles;the water must be preheating,test the heating elements and thermostat. 2) Timer: test for defective, clean contact, repair any wires loose, burn, or break. 5_9_2012_1_15_39_pm.gif
May 08, 2012 | Danby DDW1899WP Portable Dishwasher
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Water still remaining in bottom of washer after cycle is done
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Water remains in the washer after the cyle is
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
Water stay in .
Please post back here what the manufacturer and model number of your dishwasher.
Also, approximately how many years old is your dishwasher?
Can you be more specific with your problem?
If water remains after the cycle is done:
Is the water clear/clean?
How much water is left? More then 2 inches?
Please post back here with your findings, OK?
Apr 16, 2009 | Dishwashers
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
Owen Barnes
