Question about HP Office Equipment & Supplies
Ink drips out from bottom right hand corner - HP Office Equipment & Supplies
  • 186 Answers
Most probably your printer waste ink have overflow... please replace the waste ink pad to avoid further damage...and mess...
Posted on May 28, 2010
Water is leaking from the bottom corner of the freezer
Is it an excessive leak ie pools of water on the floor? If it is not a major leak it might be normal condesation being drained.
Aug 28, 2012 | Cars & Trucks
Excess ink absorber is nearly full.What do I do?
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jun 07, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to get the chat page on the right hand bottom corner of my facebook page....??? its so annoying that i dont have this page and cant chat online with my friends
click on the chat option just below your name appers(left hand side) it will pop out the chat at right hand bottom corner.
Jan 05, 2011 | Facebook Social Network
HOW DO I CHECK THE INK LEVEL ON MY HP OFFICEJET 6500 PRINTER?
I would imagine there is a program running on the taskbar (bottom right hand corner) by hovering over the icons you will see notes as to what program the icon represents. if one corresponds to the printer then click it , have a look around in that program and you will see the ink levels.
if not click the windows start button then programs to look for the HP software.
Dec 21, 2010 | Office Equipment & Supplies
How do i check the ink levels in the cartridge?
One of two ways. If the status monitor (in the lower right-hand corner of the screen) is open, double click it and it should display the ink status in that window. If the status monitor is not open, open your printer folder, right-click on the printer icon and select properties. Then in the next window, select the Maintainence tab and select "start status monitor" at the bottom. This will start the status monitor and display the ink levels. Ink levels displayed are only estimates though, as there are no sensors in this model. You should use the cartridges until you see print defects, in order to get your money's worth out of them.
Sep 30, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
The ink well is full and leaking. How do I clean it out.
There is an ink well below the home run position of the print head and cartridge assembly. If you open the lid of the printer, the print head moves to the center of the rail. You then unplug the printer and gently move the print head to the left and out of the way. If you shine a flashlight in the right hand corner or home run position, you will see the ink well. You can clean it out with a paper towel or a syringe. Obviously, the well is no longer overflowing and the drip should stop.
Apr 08, 2009 | HP DeskJet 1220c InkJet Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
