Question about Boating
Runs but wont go more then 15 MPH
Starts fine, idles out to main lake fine, but when you give it gas it won't take off or come up on plane. Engine RPM goes to 6,7,8,000. I've checked the choke, its off. I've checked for blockage in the intake, there is none. Any ideas?
  • 5,687 Answers
It sounds like the Rubber hub in the prop is slipping. There are 2 systems used to prevent gear damage, shear pins or Rubber hubs.
The outboards and I/Os' use a Rubber insert in the prop. Unless yours is an OMC all the rest use the Rubber hub that is pressed into the prop. It has to be sent to a Prop shop for replacement. Some OMC props are 2 piece inside with the prop sliding over a replaceable do-it-yourself hub insert. Its kind of slick because OMC did lower the cost of every replacement prop and keep you on the water with a fix you can do.
The RPM for your problem is the Red flag. The engine did not refuse to rev up. This means the gas and spark are working and thats all you could want.
With the RPM I suspect you are overreving the engine at 8,000. The hub will get looser and eventually you will have no propulsion.
If you are anxious to get back on the water you could buy a spare prop. Contact the dealer for any change you want to make in pitch or size.
Posted on May 28, 2010
Engine wont catch
Catch?
cranks fast
starts every time.
idles fine hot or cold , or both? hot idle not too fast.
i race engine , in park and neutral, I can hit 3500 rpm easy, can you.
i release brakes, (brakes are not packed in ICE , are they?)
I select 1gear or reverse (A/T or m/t)
the car moves or dont move, which is it, my guess catch = no move at all.
I try to drive, i look at RPM and MPH
RPM moves up and MPH track.
track means they both move in a linear progression.
RPM rises and for all RPM increases MPH also increases.
does it?
if all that works then we have an engine power issue.
weak on hills?
Jan 03, 2014 | 1998 Jeep Cherokee 4WD
Ti have a 2001 dodge dakota quad cab, 5.9 engine. when i try a drive over 50 mph it won't shift unless i really romp on the gas. its staying at 2.5 rpm while trying to drive over 50 mph. What do i
its probably the kickdown cable look under the hood its the cable that runs next to the throttle cable see if there's alot of slack or if its too tight and not letting it release all the way.
Mar 20, 2013 | 2001 Dodge Dakota
My 1997 Jimmy runs fine in idle when I take off the vechile is fine until it reaches 20 mph it won't accelerate and the rpms increase up to 3000 but no speed. What's wrong it's a 4 wheel d
Sounds like 2nd gear in the transmission is slipping. Cars usually shift at 15-20 mph from first to 2nd. First check the trans fluid.
Mar 17, 2013 | 1997 GMC Jimmy
Starts but wont idle
It may be your distributor if it seizes up when it is hot it won't idle.
Nov 21, 2011 | 1989 Chevrolet C/K 2500
1991 F-250. feul injected 460 w/c6 tranny. acts like it is missing when engine runs at 3000rpms. accelerates just fine and runs wonderfully below 2900 rpms. just when i try to plane out around 70 mph the...
Hello. katienjoe. the fuel line from the filter to the fuel rail has a restrictor in the line its at the fitting at the rail. the opening messures 3/16 of a inch. so loaded it doesn't pull above 50 mph. you can change the line I did on mine the hot rod shops can supply what you need.
Sep 14, 2009 | 1991 Ford F250
When you try to give it more gas at 50 mph, it starts to hesitate
It sounds as though your engine timing is off. Engine timing changes with engine speed. It is possible to adjust it yourself if you have the knowledge.
May 22, 2009 | 1986 Chevrolet C2500
Engine won't run properly
sounds like its running rich. check your float height and then lower your main jet needle a notch
Dec 04, 2017 | Polaris ATV
Car runs fine then all of a sudden won`t idle faster than 15 mph
i would take it in and have it checked before it leaves you stranded somewhere. theres a reason the check engine light comes on so theres something not right with your vehicle
Feb 10, 2009 | 2006 Ford Fusion
Boating Logo
102 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
