Question about Maytag Neptune FAV6800AW Top Load Washer
Butoons on contro panel don't work
When I push the buttons on the control panel, the start, off and home buttons, they do not work. I can push the back button to get to different sceens, but the start and off buttons do not work.
What might the problem be?
  • 526 Answers
Cheryl,
I understand what you said. It sounds like your machine is the FAV9800A LCD Maytag Neptune TL. Is that correct?
If so try to power Cycle the washer control board by unpluging the washer 120VAC power for 30 seconds then re-power bach up.
If that dosen't clear the issue you may have a Control Board failure or issues with the KeyPad ribbion cable from the Console to the to the Control Board.
Here is the Service Manual for for the FAV6800A and your machine I believe FAV9800A. If you could confirm your model number.
Service Manual for reference. Sears Parts Direct for reference.......Rich
Posted on May 28, 2010
  • 159 Answers
I cant understand what you said!
  • chrizzoclark May 28, 2010
    I dont understand what you said!
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
I have a maytag dishwasher model mdbh985aws1that stopped working. The controls buttons on the left light up when pushed but the buttons on the right (including the start button) do not work. Any ideas on...
The CONTROL PANEL and/or ELECTRONIC CONTROL BOARD are broken. Unless you are good with a multimeter and wiring diagram just order both and send back the parts you don't use.
Aug 26, 2012 | Dishwashers
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Does not work
Hello
Check its battery contacts first. In remote controls, if battery contacts get rusted or dusty, proper battery connection will not occur. If battery contacts are good, check its infrared emission. You can check it with the help of a cellphone with camera option. Put the cellphone to camera mode, and place the remote control just one feet away from its lens, and push each button on the remote control. Eventhough human eye cannot detect infrared rays, electronic cameras can. If there is infrared rays emitting, you can see its image on the cellphone screen. If not, be sure that the remote contro is faulty. If there is infrared image, and still the device you wants to control does not respond; infrared sensor inside your device is faulty, and should be replaced. OK.
Jun 15, 2011 | Radio Shack (15-2147) Remote Control
Push start button but drum does not turn. All the display controls look as if they are working. I can hear a click when I press the start button.
if the contro panel lights up but the drum will not turn ,unplug unit remove toe panel and check thermal fuse for the motor right in front has two blue wires going to it
Jul 18, 2010 | Whirlpool GEW9250 Electric Dryer
Bose Av38 Media center remote contro issue.
problems of conectivi betwen samsun and bose products many people whit same problem,
Mar 25, 2009 | Bose Lifestyle 38 System
Whirlpool Duet Dryer has a mind of it's own, cannot change contro
First of all check to see that the control panel is not locked. There is a lock button assigned on the control panel. It should say it next to one of the buttons. Not door locked. You have to hold that button in for 5 - 10 seconds to unlock the panel. If not, you may need a new panel, happens often, its part # 8558753 depending on the color. Thanks Dave www.washermd.com
Dec 12, 2008 | Whirlpool GEW9250 Electric Dryer
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Maytag Neptune FAV6800AW Top Load Washer Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
