Question about HP DeskJet F380 All-In-One Printer
All lights blink continuosly indicating an error
  • 241 Answers
You can try shutting down the printer and unplugging it, then restarting to see if it resets the printer. If it continues to do this check to see if a job is still pending in the printer que, if so try and delete print job or shut down your computer and printer, then restart. If you have a paper jam, sometimes this is your printers way of indicating that you do. Check all paper paths to see if there is a small peice of paper lodged inside, carefully remove the paper and reset the printer by turning it off and back on after 10 seconds. You can also look in your manual sometimes in the back it gives a list of error codes and solutions to resolve the issue. If after all of this your printer is still flashing check with your local printer repair shop to do an assessment to see if it could be any other issue.
Posted on May 28, 2010
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
Feb 15, 2016 | Televison & Video
Tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
on Mar 31, 2011 | Office Equipment & Supplies
Lg tv standby button keeps flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 16, 2014 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Toyaota Camry 1994 engine won't start, Engine light on
I would check for fuel,(pressure and injector pulse), spark, and compression, before checking any codes. Lack of any of these basics can result in codes, and then you waste alot of time chasing a symptom, instead of the actual problem.If more people followed basic diagnostics, which always come back to these three basics, rather than chasing codes first,they would find no starts much more quickly.
Nov 14, 2011 | 1994 Toyota Camry
When i turn tv on it clicks. the red light blinks 9 times continuosly and the screen stays black. what is the problem?
Thats indicating the set has shutdown due to audio problem on the A and B boards. You can get a replacement A board which has the B board already on it from www.tvrepairworld.com
Jun 28, 2011 | Sony KP-51WS510 51" Rear Projection...
The tv went blank @ the red led is flashing continuosly sony kds-60a2020
If its lamp light on tv front that is blinking red then lamp is dead/ broken and need to be replaced. Lamp replacement procedure is easy and written in user mnaual of tv.
If it is standby/ power light that is blinking then please count how many times it is blinking after three seconds pause and let me know to diagnose tv problem because it is an error code that has info in its blinking.
Thanks.
Apr 03, 2011 | Sony KDS-60A2020 60" HDTV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
Blinking light
H4 is a fuser error, check the continuity of the fuser lamp.
Aug 27, 2007 | Sharp AL-1217 Copier
HP DeskJet F380 All-In-One Printer Logo
164 people viewed this question
Seeker5211
Seeker5211
