Question about iLO (2 GB) MP3 Player
Power My ILo wont even turn on
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Ilo 32 inch LCD wont turn on
power supply bad inside of tv
Aug 28, 2009 | iLO 2600 Television
It wont turn on even with a new battery
I had this problem with my ILO MP3 player - I ended up taking it apart and discovering that the power button wasn't making direct contact with the switch - made a small adjustment and it's been working ever since - hope this helps
Aug 12, 2009 | iLO MP3 Player
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
Dec 18, 2008 | iLO 2600 Television
It wont turn on it justskeep flashing ilo
try connecting it to your comp or any other charging device, then turn it on-off
Jun 18, 2008 | iLO (2 GB) MP3 Player
Wont' turn on
HI
Ilo Mp3 Player is weak in Power button so many people get same problem open the case and reinsert the power button still not working, change the rupper piece under the power switch
Bye Take Care
Apr 15, 2008 | iLO (2 GB) MP3 Player
ILO wont work
One of two things..try a new battery...or it's possible that your button lock button is in the lock position ( look under the power button make sure it is pushed up)
Dec 24, 2007 | iLO (2 GB) MP3 Player
What's going on?
Bad power packs. Known issue which Walmart will not fix.
Oct 08, 2007 | iLO 3200 32 in. LCD Television
TV WONT TURN ON
try pressing the channel or volume buttons. They turn on the tv as well. Maybe the the remotes might cooperate with the tv.
Jul 22, 2007 | iLO 3200 32 in. LCD Television
iLO (2 GB) MP3 Player Logo
26 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
