Question about HP Officejet 5510 All-In-One Thermal Printer
Printer won't print
I'm pretty sure the reason is that it is in "fax" mode. We never fax and I don't know how it ever switched but I don't remember how to switch it back to "print" mode.
  • 28 Answers
I would gather that you need to get back in to menuy and got to fax mode , but make it state auto fax mode
so that when faxing is complete it will auto go back to printer status
we get the same thing here at my work but me making the menu go into auto fax mode seems to handle the trick
i hope tihis is helpfull and if not let me know cause thats all we use here at work is hp all in one printers i will check for you and just give me model number ok
richard from chicago
Posted on Apr 07, 2008
6ya staff
SOURCE:
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
My printer is stuck. Won't work. It keeps indicating fax mode. Strange thing, I have never actually hooked the fax up. how do I get it back to printing
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.If not then follow the following steps.
Please be informed that any Printer Driver software depends upon the hardware make and Operating System. You need to know all these information's to do get going.
Please find the Driver software's of your printer inside the installation disk provided with the Printer at the time of purchase. As you have not mentioned your Printer make I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the Printer.
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Printer Model number and the OS that you are using.
To install just Double clock on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
If you feel that my answers have helped you getting solution to your problems then please give a vote for best answer.
Thanks.
Nov 27, 2012 | HP officejet 4200 series
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
NO user manual for new 5300 printer!!!!
If you want to switch to photo mode you have to have photo paper in the printer. As for the user manual you did get one, just not in paper form. Kodak has the user manual on the software CD or you can go to kodak.com. The reason it's not in paper form is because the user manual is more than 100 pages.
Oct 31, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Command print, set up like it will print, but immediately brings up fax form to be completed for faxing...............unable to get print. Suggestions? Thanks, Dave
Make sure your printer is set as the default printer in the control panel of your printer. You fax mode could be setup for default causing the problem.
Jul 13, 2008 | HP Officejet 5510xi Printer
Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Jan 05, 2007 | HP LaserJet 2840 All-In-One Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
157 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
