Question about Speed Queen AWS44NW Top Load Washer
Making noise when spinning
When spinning the machine makes a funny noise and starts leaking water
  • 159 Answers
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
Posted on May 28, 2010
Machine will not drain
probley somthing in pump ie coins
Apr 16, 2015 | Washing Machines
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What would make my washing machine leak water and make a funny noise?
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
Oct 22, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Kenmore HE2 110.4751
for the F10 code ? Unplug the washer open chech the funny noise / belt are worn out / slap to the brackets and other near obstacles . Replace belt broken.
Detergent leaking /ovewr flow clean w/ fish nylon # 150 just 40 cm /insert in the hole put water to soften the hard detergent forward and backward to clean detergent hose.
Nov 15, 2007 | Kenmore 43142 Front Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Speed Queen AWS44NW Top Load Washer Logo
290 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
