Question about Panasonic Televison & Video
My TV is a Panasonic model TX - 28MK1F / M with the manufacturing date of 1999. The problem is that pressing the power button at the top tunes and connects but after a few minutes or seconds (depending on day) automatically becomes the sole in sleep mode (Stand-by). At first made him very often, but lately it has become increasingly common, and now now now no longer have time to automatically tune to any channel that passes quickly into sleep mode (stand-by), without being able to see any television program. What is it that happens? That is what I can do? , Can you help me with the solution of the problem?. Thanks. A greeting.
SOURCE: LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Posted on May 13, 2008
SOURCE: No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Posted on Jan 13, 2009
  • 718 Answers
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
  • 165 Answers
SOURCE: Grundig T51 640 text TV
http://safemanuals.com/brand-user-guide-instructions-owner-manual/GRUNDIG
get the user manual from this link click it and download it .
Posted on Feb 20, 2009
SOURCE: teac hdb820
I just did a factory reset this morning and I had the same problem until I realised that you have to use the "Output" button to get the Video Outputs to DVI Digital (see page 17 of the manual), if that's what your connection is, then I could select "menu" and do a channel search. Hope this helps.
Posted on May 30, 2009
I have a Panasonic TX-48CX400B and can't find the pip button how do I get split screen off tv.
The PIP mode is only used to show the current source if you are also looking at the Internet portal mode. After you set up your network connection, press the Internet button on the remote to access the network options. (That's the button with the globe and an arrow that curves up from the bottom right of the globe.) Press OK to select an internet option.
See page 28 of the manual for more information. (I found the manual for the TX-48CX400E here, http://www.panasonic.com/uk/support.html , and looking through the list of LCD TV models. Then click on the Downloads link and then choose the version of the manual you want. From here, you need to accept the Panasonic terms of use for their downloads. The direct link to the manual is http://tda.panasonic-europe-service.com/docs/2z56564c5ez3z3bebbz656ez706466z23zba9e6b6cadec0298b6a49aa5ad340d60c1bb0f19/pgrp001/pcat033/tx48cx400e/933026/BG1WLCAKK3RR.pdf . This is the same model sold in another country.)
I hope this helps.
Nov 25, 2015 | Panasonic Televison & Video
How do l get into the panasonic Tx39in a300b hidden service menu
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Panasonic Televison & Video
Panasonic tv model tx 29rx20m no tuning
i lose resister R889 with panasonic TX-29RX20M,so cant u ask me wht the point in resister,or ohm?
Dec 18, 2011 | Televison & Video
Sony 52 inch, model number kp 53n74, stopped working
I have the same model Sony TV with a September 1999 manufacture date just did the same thing Friday! How are we suppose to find out what's wrong
Feb 22, 2010 | Sony Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Panasonic tv tx-32pk with no power.
ic wil damaged...otherwise plz use another plug board....may be ur switch board complaint
May 07, 2009 | Panasonic TX-32PK1 TV
I want the sky remote to put the volume up and down on my panasonic tv so i need a code, model no th-42px80b,thanks if u can help.Colin
Hello Colin
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 26, 2009 | Panasonic TX-28DK2 TV
Code for panasonic tv
ineed the code for a panasonic ct-27sx12af
Dec 01, 2007 | Panasonic CT-27G11 27" TV
Televison & Video Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
