Question about Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 battery not charging - Dell Inspiron 1525 Laptop Jet Black
  • 942 Answers
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
Posted on May 28, 2010
myrlex
  • 674 Answers
SOURCE: Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Posted on Jun 08, 2009
SOURCE: dell inspiron 1525 will not charge the battery
PROBLEM FOUND AND FIXED!!
The problem is as JCHUNTER identified. On my Inspiron 1525 I got the same dreaded message "plugged in...not charging." What I found is this: The problem is NOT the charger. the problem is NOT the motherboard (at least it wasn't) on mi laptop. The problem is the jack on the laptop that the charger plugs into. There are 3 metal contact parts on the charger jack that mates with three essential contacts in the charger input jack on the laptop. If you look at the charger tip you will notice (1) the outside metal piece, (2) the inside of that same outside metal piece, and, (3) (the metal tip inside that looks like a piece of bare silver wire (forgive me, I do not have the technical terms). If you look inside the power input jact on the laptop (does not require any opening of the laptop) you will see a rounded black piece in the center of the input. This iw where the problems lies. There are four metal contact points on that inside piece that must be in contact with the inside metal on the charger (#2 above). Over time, these four metal contacts gets pushed inside the rounded black center piece on the input jact so that they fail to maintain constant contact with the corresponding area of the charger, so you get the dreaded message.
Here are possible fixes:
1. replace the sub-board on which the power input jack & USB jacks are located (I do not know if all inspirons have this sub-board but mine did). To me it was not that difficult to open the computer and take that part out. P.S., I did not even have to remove the motherboard. OR
2. Replace just the power input jack (if you are good with soldering micro circuitry. Do so at your own risk. OR
3. This is what I did, and it worked like a charm. Find a way to pull out the four metal contacts on the inner black piece of the input jack of the laptop. This requires a little ingenuity and some patience. I took a straight pin and using a pliers bent the point so that it formed an "L' shape (the bent piece should be short enough so that you can fit it inside the powe jack and maneuver it around). Hook the bent end of the pin under each of the four contact pieces and gently pry them outward. It is my belief that as long as at least one pin gets contact with the charger that it should work.
(Some people suggested banging the laptop or wiggling the charger tip and some strange other tactis, which appear to work for some people. I have tried them and found that some work intermittently at best. They will work only as long as there is contact of the two parts I mentioned above).
To arrive at my solution, I opened up my Inspiron 1525. I put a multitester on the power input jact and realized that there was no problem with the sub-board or its connection to the mainboard. I tested the charger and that was fine also. Next I checked the power input jack and the contact points I identified as 1 and 3 above had good contact. It was difficult to check no 2. For this, I used a piece of tin foil placed inside the charger tip before inserting the charger tip into the power input jact on the laptop - and WOW, IT WORKED - NO MORE MESSAGE. I unplugged and removed the foil and.. you guessed it... the message was back. So, I knew that this had to be the problem. Since I used method 3 above, my laptop has been working like a charm, even after multiple times reinserting the charger into the power input jack on the laptop.
This is only my experience. I am no expert. I am just some one who uses self to save tons of cash.
HOPE THIS HELPS SOMEONE!!
Posted on Apr 12, 2010
tecnomage201
  • 221 Answers
SOURCE: battery of laptop not charging
If the laptop works when plugged in, the power supply is OK. The battery controller is probably the problem, which would mean replacing the battery.
Posted on Apr 17, 2010
  • 19 Answers
SOURCE: dell inspiron 1525 battery not charging
1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
source from laptop battery site:http://www.buy-battery.ca/faq.htm
you can buy replacement Dell inspiron 1525 Battery there:)
Posted on May 27, 2010
  • 19 Answers
SOURCE: I have a dell inspiron 1525 the battery light was ...
It means the battery charging.if you want to buy new on, you can see one here: canada: <a href="http://www.buy-battery.ca/laptop-batteries.php/1+replacementfordell+inspiron--1525">dell inspiron 1525 battery</a>
usa:<a href="http://www.all-batteries-shop.com/compare-batteries.php/1-128528-replacementfordell-inspiron-1525-battery">dell inspiron 1525 battery</a>
Posted on Aug 10, 2010
Warranty check battery
please test the adapter first, measure the output from the adaper see what is the exactly voltage, and if the voltage is NOT there the problem can be the adapter. Otherwise if there are the problem can be battery. However use the software diagnostic coming with the computer, and use for to test the battery chargin.
God bless you
Jul 04, 2013 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
Time of day clock stopped - DELL Inspiron 1525
This is one of the known issues with the Inspiron 1525 computer.The problem is caused by faulty cmos battery. If you computer is in warranty kinldy call Dell to get the same replaced . if the system is out of warranty. You would need to replace the CMOS battery ie below the keyboard.
You can follow the instructions below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/coinbatt.htm#wp1179839
Thanks
Proton
Feb 06, 2010 | Dell Inspiron 1525 Notebook
I want to buy a Dell inspiron 1525 battery
Yes. you can go to that link,I cannot find anysite offering less than that with one year warranty even in Amazon.
I will also remember the site name for my future use.
Thank you.
Dec 28, 2009 | Dell Inspiron 1525 Laptop
Where I can find a battery for Dell INSPIRON 1525 ?
Dell 9-Cell Battery : Here
Dell 6-Cell Battery : Here
If I was helpful, Kindly do Rate!
Regards,
Waqar.
Sep 03, 2009 | Dell Inspiron 1525 Notebook
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
358 people viewed this question
Alun Cox
