Question about Craftsman 26 Hp 54" Deck Yard Tractor
The service manual shows 4 grease fittings but I can find only two. Where are the other two?
  • 66 Answers
Should be two on the front axle (one on each side). Some come with greaseable spindles but that would make 5. Check the steering linkage on the bottom and in next to the steering gears. www.nnyparts.com
Posted on May 30, 2010
Where are the grease fittings
Gary, You should consider getting a manual, Check the attached links,instruction and guides on where to find grease fittings on ATV's, Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Atv Maintance Grease Fittings
Can Am Outlander Renegade G2 Grease Fitting Locations
Time to Lube Up Your ATV Dennis Kirk Powersports Blog
Service Manuals for Download in PDF
Mar 31, 2016 | ATVs
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
What are the locations of the grease for the front end of 97 mercury sable..
You most likely don't have any grease fittings. Most front ends are "lifetime lubricated", and they save money by not putting zirc fittings on them.
May 09, 2015 | Mercury Sable Cars & Trucks
Singer Model 3116, I am doing some maintenance on this machine and there is no grease on any of the gears. Do these gears need greased?
here is a free manual from singer, look in it and see if it show about
oiling the machine, if it doesn't contact singer and see if the machine
is one of the self oiling machines
http://www.singerco.com/uploads/download/438_3116.pdf
Customer Service: 1-800-4-SINGER (1-800-474-6437
Nov 15, 2012 | Singer 3116 Simple
How do you service, ie grease the shafts that hold the mowing blades, I see no grease fittings. It is a 638 RL Yard Machine
Hi, they run sealed bearings with no grease nipples. I replaced my bearings when they became noisy and drilled and tapped the housing and fitted grease nipples to extend the service life of the bearings. Hope this helps, regards Phil.
Jul 19, 2011 | Garden
ARE THERE GREASE FITTING ON THE FRONT END OF THE 2005 AND 2007 F 150 TRUCIS. I SNED MY FLEET TO BE SERVICED AND THEY COME BACK STATING NO LUBE
Grease fittings don,t come on new trucks anymore
I Have 2005 F 350 and a 1999 F450 and there is no grease fittings
Aug 30, 2010 | 2005 Ford F-150
How many grease fitting are on a 2002 chev blazer, 4 wheel drive ?
Will very. Alot of the parts on the new cars are sealed and wont have grease fittings but when parts of steering and suspension are replaced then the have grease fitting so honestly it can very from car to car.
Feb 03, 2010 | 2002 Chevrolet Blazer
Reebok demon 2007, tools for servicing it?
If you are re-greasing the hubs you need a minimum of 4 speciality tools. A 12mm, 13mm, 14mm, & 15mm, cone tools are required for this job. There are many brands of cycling grease out there. Any bike shop, (usually not department stores) have bike grease, although you can use automotive grease. GO TO Parktool.com for tips.
Mar 22, 2009 | Cycling
50,000 mile service
48,000 miles or 48 months
Maintenance Service Schedule 2007 dodge
Change engine oil and engine oil filter
Rotate tires
Lubricate drivetrain / steering / suspension
grease fittings (if equipped)-except Powerwagon
Lubricate front drive shaft fitting
(2500 / 3500, 4X4 & Powewagon)
Lubricate tie rod end links - Powerwagon
Check automatic transmission fluid level
Check manual transmission fluid level
Check the coolant level, hoses and clamps
Inspect exhaust system
Inspect brake hoses and brake linings
Inspect the CV joints/U-joints (if equipped) and
front suspension components
Check spare tire for proper pressure & correct
stowage
Lubricate outer tie rod ends 2500/3500 4X4
51,000 miles or 51 months
(2500/3500, 4X4 & Powerwagon)
Inspect brake hoses
Jan 04, 2009 | 2007 Dodge Ram Truck
Cant find grease sert on front end? 06 ram 2500 4x4.
if there is no fitting it is a "sealed" joint... either drill out a hole in the end and add a fitting for grease.... or when it fails replace it with one that has a fitting. i believe most hardware stores stock grease fittings
Robert
Dec 19, 2008 | 2006 Dodge Ram 2500
Craftsman 26 Hp 54" Deck Yard Tractor Logo
122 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
